t-18 tranny with granny gear HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2012, 08:12 AM   #1
Thetreeguy
Default t-18 tranny with granny gear HELP
Its a 78 and had to pull start it since the flywheel was shot and needed to drive it to my shop to replace the ring gear. Well when I pull started it the shift got stuck in second. the clutch disengages when i push in the clutch but still won't come out of second the shifter seems to be jammed I haven't attempted to do anything yet. Any thoughts on what could cause this problem?
Thetreeguy is offline   Reply With Quote
Old March 24th, 2012, 09:43 AM   #2
bigblocked
bigblocked's Avatar
You probably just have a misalignment in that old girl. Have someone rock it back and forth with the clutch engaged while you shift it out of gear. Its happened with mine and usually only happens when you dont drive it for a long time. Good luck.
Then when you have time............
http://www.ebay.com/itm/Ford-T-18-T1...sories&vxp=mtr
bigblocked is offline   Reply With Quote
Tags
ford, shift problems, transmition
Page generated in 0.26142 seconds with 29 queries
