95 pstroke is pissing my off!! need help - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2012, 10:00 AM   #41
Elvis13
The white smoke is probably from glow plugs not working. As the oil warms up it will get thinner and could cause high pressure oil issues. You need to be able to check your high pressure oil psi.
Old May 8th, 2012, 12:59 AM   #42
red87chevy
red87chevy's Avatar
Ok what should the hpo be? 500-600 right? And is still running like crap no power white smoke and random stalling
red87chevy is offline   Reply With Quote
Old May 8th, 2012, 09:29 PM   #43
Elvis13
Lightbulb
No fucking shit, you are on the 3rd page of people trying to help you but you still fail to do what they advised. Here, let me give you a free bump so more people can can advise you shit that you won't do. Look below asshole.
Originally Posted by TIRES_ARNT_CHEAP View Post
The 7.3 powerstroke is a great engine. It is very simple to work on also. A POS autozone scanner will not do the job. You need someone with a snap-on MT2500 brick scanner to look at it. You first need to do an injector buzz test. If it fails inspect the wiring harness where it goes through the valve covers. The glow plugs are also powered through these plugs and on a duty cycle they draw a ton of juice and will melt plugs. If it passes that you need to do a cylinder balance test. If it passes that You are pulling all the injectors to replace all the o-rings and disc seals. The white smoke once it warms up under load is unburnt fuel. Bad o-rings or disc seals will let fuel leak into the cylinder. This being the white smoke. The only way to diag that truck is with a scanner and not a cheap one. I have been a powerstroke tech for ten years.
He says this (above) and you do this (below), you're a fucking idiot? Good luck installing your smoke switch dumbass.
Ok replaced the cps senser ebp sensor and tappit cover gaskit on drivers side and unpluged the fuel bowl heater it runs now but stalls once hot? Any ideas? Seems to be electrical somewere cuz it smoke white sometime then clears up?
Old May 8th, 2012, 09:41 PM   #44
MilwaukeeF350
Dan
I am reading this thread and think how you waste time.
FIND SOMEONE with scanner that work on powerstroke 7.3L
I would drive to Caro but not for free help.
Old May 14th, 2012, 11:17 AM   #45
red87chevy
red87chevy's Avatar
Elvis13 praying for ya bud you need it! But anyways i cant find anyone with a scanner to come out and scan it im offering money! And can drive it anywere and no one has a truck to haul this with and i reAlly dont wanna touch anything till scanned
Old May 14th, 2012, 11:59 AM   #46
Elvis13
Hahahahaha, this guy pm's me to tell me i'm being mean. Why does everyone in this country act so helpless and want people on the internet to do everything for them.
YOU HAVE TO SCAN IT, stop bumping this thread and asking for suggestions you're wasting your time. Obviously, you don't know how to fix it, get it to a proffessional.
Heres an idea, type in yellowpages.com into your browser.
Type in tow truck
Call local towing company
Call Ford dealer or mechanic shop
let them know it's coming there way
and then you can quit pretending to be helpless.
Old May 14th, 2012, 12:11 PM   #47
red87chevy
red87chevy's Avatar
Not helpless bud just busy is all but the invite is still on the table :)
Old May 30th, 2012, 10:08 PM   #48
mattt8430
Had lots of injector problems on these, o-rings on the injectors roll causing low power when they heat up and a grayish smoke, need to watch the injector pressure while running with a scanner, it needs 500psi to even start, hope this helps
mattt8430 is offline   Reply With Quote
Page generated in 0.26494 seconds with 47 queries
