95 pstroke is pissing my off!! need help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2012, 06:24 PM   #1
red87chevy
red87chevy's Avatar
Default 95 pstroke is pissing my off!! need help
I just bought this truck to be a tow rig
Its got 130k 2wd 5speed
I got 20 miles from were i bought it and it blows a fuel line some one put just reg no pressure 3/8 rubber line on there
Fixed that on the side of i96
Got it going made it 30 miles them check engine lifght white smoke and no power!
Replaced the egr presure swicth (cuz i broke it of with my knee changing lines)
Got it runnin again and ran ok took it down the road and the light came on again so
I changed the fuel filter and the tappit cover gasket and harness
Still doing it!! I live out in the middle of no where and i cant drive it to get it scanned
Any help would be nice
red87chevy is offline   Reply With Quote
Old March 18th, 2012, 06:30 PM   #2
Freak
Wheelin the HD
Freak's Avatar
Sell it.
Old March 18th, 2012, 06:35 PM   #3
red87chevy
red87chevy's Avatar
Trust me im thinking about it!!
Old March 18th, 2012, 06:54 PM   #4
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Freak View Post
Sell it.
helpful post is helpful
Old March 18th, 2012, 07:00 PM   #5
badazzchevy
go big or go home
badazzchevy's Avatar
So is spell check
badazzchevy is offline   Reply With Quote
Old March 18th, 2012, 07:16 PM   #6
red87chevy
red87chevy's Avatar
Srry on my android buttons are to small!!
Old March 18th, 2012, 09:41 PM   #7
Elvis13
So what is it still doing, white smoke and no power?
Old March 18th, 2012, 09:49 PM   #8
red87chevy
red87chevy's Avatar
The smoke cleared up but it is running rough and no power then warms up and thros a ce light and then no power
Old March 18th, 2012, 09:53 PM   #9
Elvis13
White smoke is usually unburnt fuel, on startup it usually means one or more of the glow plugs are not working, but the no power could be something else.
This will be really hard to diagnose via the internet without a scan. Do you think your turbo took a shit, or possibly that fuel line blew off something that would regulate/read boost?
Old March 18th, 2012, 10:12 PM   #10
special k
special k's Avatar
could be an IDM(injector driver module)
Old March 18th, 2012, 10:34 PM   #11
red87chevy
red87chevy's Avatar
It has power till the check engine light comes on then no longer spools up
When i bought it it ran greAt now it doesnt once warm and sometimes idles rough...what is the fuel pressure sapose to be on the 95s?
Old March 18th, 2012, 10:38 PM   #12
rreed101287
i have a 93 acted just like that it was the injection pump. the fuel line breaking probably caused the pump to take a shit
rreed101287 is offline   Reply With Quote
Old March 18th, 2012, 10:41 PM   #13
special k
special k's Avatar
95 isn't high pressure fuel, it's HEUI(Hydraulically actuated, Electronically controlled Unit Injector), so high pressure oil. could be a weak high pressure oil pump possibly
Old March 18th, 2012, 11:58 PM   #14
Elvis13
My 6.0 HEUI runs 50psi + for fuel.
Old March 19th, 2012, 11:51 AM   #15
red87chevy
red87chevy's Avatar
Idk the gauge has it in the normal oil pressue in the gauge but i havent check fuel pressure yet im gonna after work hopefully what is it sapose to be?
Old March 19th, 2012, 12:07 PM   #16
mudrunner78
mudrunner78's Avatar
What exactly did u break? Those engines dont have egr. 6.0L were the first in 2003. Did u break the icp sensor on accident?
mudrunner78 is offline   Reply With Quote
Old March 19th, 2012, 03:33 PM   #17
Elvis13
The stock oil pressure gauge is measuring low pressure oil created by your oil pump.
HEUI diesels have a gear driven HPOP that creates high pressure oil to fire your injectors. The ICP or IPR will monitor and regulate your high pressure oil.
Old March 19th, 2012, 11:12 PM   #18
red87chevy
red87chevy's Avatar
No it was the egr pressure regulator i just bought on for a 95 pstroke and yes i kno that it but it is a indicator of low pressure from the hpop
Old March 20th, 2012, 10:59 AM   #19
red87chevy
red87chevy's Avatar
Bump
Old March 20th, 2012, 01:17 PM   #20
Elvis13
HUH? Egr pressure regulator? What are you saying?
My guess is that you replaced the IPR.
Why did you type bump? is it fixed?
Page generated in 0.42705 seconds with 83 queries
