2002 explorer xls hvac - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2012, 03:03 PM   #1
eagle-eye
Default 2002 explorer xls hvac
Blower motor works fine, ac works, temp control works, however if you try to switch from defrost to vent, it doesnt work. I dug into it a little bit and found that the red line going to the vacuum operated actuator is getting no vacuum at all. Which line is the vacuum supply? Is there anywhere i should look specifically for a leak? does anyone have a vac diagram for this? there are five-six lines going into the controller but i have no idea which is which.
Thanks in advance for the help.
eagle-eye is offline   Reply With Quote
Page generated in 0.17804 seconds with 26 queries
