american made clevis' - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2012, 09:59 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default american made clevis'
where can i buy some? prefer 1/2" up to 3/4" all the places i seem to find only have made in china or made in india ones.
Old March 18th, 2012, 12:00 AM   #2
1 ton tj on 40's
1 ton tj on 40's's Avatar
there is a place in burton i think there name is ropes an chains thats where i got mine they have a lot of crap an good prices i will look up there # for ya in the morning. they deal with a lot tow trucks an stuff good people.
Old March 18th, 2012, 07:24 AM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Fastenal sells USA, they are Orangeishred in color. China ones are Blue in color.
Old March 18th, 2012, 07:54 AM   #4
Cowboy Dodge
will work 4 sex
Cowboy Dodge's Avatar
fastenal, grainger, etc... shackles are the screw types proper name ~ clevis is a pin with a cotter pin. Crosby is the most common usa brand, try to search~ Crosby shackle~
Cowboy Dodge is offline   Reply With Quote
Old March 18th, 2012, 09:57 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
when i search shackle it always seems to come up with leaf spring shackles. clevis usually brings up what i'm looking for. i'll look into fastenal and that rope and chains place.
Old March 18th, 2012, 10:00 AM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Grainger has some silver USA made rust resistant shackles.
Old March 18th, 2012, 10:15 AM   #7
1 ton tj on 40's
c@w wire rope @ supply co inc 3347 E-bristol rd burton mi 48529 # 1-810-742-2090. they will have what your looking for an good people to work with hope it helps you out.
Old March 18th, 2012, 10:39 AM   #8
Mclovin
"The Situation"
Mclovin's Avatar
www.zips.com they have a store opening in Taylor soon. but they ship nationwide from Iowa.
Old March 18th, 2012, 10:42 AM   #9
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I would buy a china one if you want quality...if you want overpriced metal that will break go for the USA
Old March 18th, 2012, 10:50 AM   #10
bigbchevy
missmrgreenagain
bigbchevy's Avatar
C&m wire rope on Judd in Burton is also good
H.o.r.e
Old March 18th, 2012, 11:59 AM   #11
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
actually the reason i want usa made ones is because i have broken 2 china made ones. ripped the screw pin right out of the shackle. when they say 10,000lb capacity i guess they weren't kidding.
Old March 18th, 2012, 12:32 PM   #12
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
so you put more force then what they were rated for?? If so I don't think it matters if it was USA or China made.
Old March 18th, 2012, 01:23 PM   #13
Pop-Tart
Pop-Tart's Avatar
The steel the USA ones are made with probably came from china.
Pop-Tart is offline   Reply With Quote
Old March 18th, 2012, 03:53 PM   #14
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
that was working load limit. maximum break strength was supposed to be 4 times greater. i don't know how a stock s-10 can put that much force on just pulling out a stuck jeep. i had a 3" recovery strap rated at 30,000lbs you would think that would have broken first. i have found out though alot of that cheap shit is rated way more then it can actually take.
Old March 18th, 2012, 04:02 PM   #15
Yota Bill
If you ripped the screw pin out, you are using it wrong. The load should never be applied in a direction that will try to spread the shackle, or put the load on the threads of the screw pin.
Put the shackle through the eye of the strap so the strap sits in the curve of the shackle, then align the shackle on the vehicles D-ring and put the screw pin through the shackle and the D-ring, so the D-ring is on the screw pin. There actually should also be washers on the screw pin to take up the space and keep the shackle centered on the D-ring.
Old March 18th, 2012, 04:14 PM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i know what your saying but this was not the case. the screw pin ripped the holes open on both sides.
arrows indicate the direction of the pull. the sprayed gray was the bottom of the shackle ripped out.
Page generated in 0.46135 seconds with 71 queries
