6.0 injector to oil rail o-ring kit - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2012, 09:45 PM   #1
cbrandsen
Jeeps...a way of life
cbrandsen's Avatar
Default 6.0 injector to oil rail o-ring kit
Ford tells me that the oil o-rings in the top of injectors can't be serviced. Does anyone know who offers this kit? I know the o-rings can be replaced by removing D clips on top.
I heard a company alliant who makes the injectors for Ford/International may offer this kit. Does anyone know if this is true or who else makes this kit?
cbrandsen is offline   Reply With Quote
Old March 23rd, 2012, 10:04 AM   #2
ThinICE
Awesome-O
ThinICE's Avatar
The o-rings that interface between the injector and the rail can't be replaced per Ford only because Ford doesn't have the parts and there isn't an "engineered" method for replacement. The D-ring can be removed and the o-rings replaced, it's been done before. As far as who makes the kit... I spent about 5 minutes on Google and found a few places. Just remember, if you're in there replacing the o-rings for the injectors, might as well do all of the o-rings and also replace the dummy plug/stand pipe o-rings too. All of that has to be removed, so might as well replace.
ThinICE is offline   Reply With Quote
Old March 23rd, 2012, 11:06 AM   #3
Elvis13
If you don't have the updated stand pipes and dummy plugs you may want to update the entire pipe/plug while you're in there. The old ones will not have the nylon washer.
Old March 23rd, 2012, 11:15 AM   #4
ThinICE
Awesome-O
ThinICE's Avatar
Gracias Elvis13, and great point.
Old March 25th, 2012, 11:12 PM   #5
cbrandsen
cbrandsen's Avatar
Yeah I googled the o rings and found them through Alliant Power. Diesel Injection Service had them in stock along with stand pipes and dummy plugs. Truck had a high pressure leak between oil rail and injector 7, once the oil got hot and thin the truck would not restart. I replaced all oil rail o rings, body o rings, stand pipes, and dummy plugs. Starts fine and customer was happy enough he already brought more work. Last time I had the same issue it cost the customer 8 injectors also so these kits could be very valuable to some techs. Thanks guys
Page generated in 0.29386 seconds with 38 queries
