Dana 44 (99 Dodge Ram 1500) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2012, 01:04 PM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default Dana 44 (99 Dodge Ram 1500)
Im wanting to make up setup bearings/races to aid in my gear swap. I ordered the motive gear RA28FLRMK master install kit. I had thought for the most part that on Dana Axles the pinion depth and preload is set by shims between the races and housing. This kit comes with a crush sleeve so obviously that will be my preload setup. Now the part that is confusing me is that for the pinion shims they included kit 1113 which is way to large to go between the pinion and inner bearing. So it should go between the race and housing. Now my question is if this is the case is it ok that the Shims are larger than the inner pinion race? If i lay the race down over the shim there is roughly a 1/16th of an inch or a tiny bit more around the whole circumference of the race, that the shim is larger? Is this okay, i just called motive about it and the guy didn't think that seemed right at first but while on hold he was looking into it and was told that it is ok that the shim is larger and they've sold alot of the kits and have not had any problems.
So, to make my setup bearings/races; I would need 2 carrier bearings and an inner race and thats it in this case?
BowtieWrangler is offline   Reply With Quote
Old March 16th, 2012, 03:04 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Provided the shims fit in the race bore, yes. I'd recommend doing the ID of the outer pinion bearing just for ease of assembly.
Old March 16th, 2012, 03:16 PM   #3
BowtieWrangler
thanks for being helpful with my questions as always
Old March 20th, 2012, 06:25 PM   #4
DodgeDude99
on my '99 Ram, the shim was between the pinion and bearing, on the 44 that i had swapped on my K5 it was between the race and housing.
DodgeDude99 is offline   Reply With Quote
Old March 21st, 2012, 07:05 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
The shim is on the pinion from the factory. Most aftermarket installation kits include shims to put behind the inner pinion bearing race. I'm not aware of any axles that come from the factory with shims behind the race.
Old March 23rd, 2012, 11:01 PM   #6
DodgeDude99
the kit for my dodge had the shims for both.
the old 44 was factory with the shims behind the race as it was never opened up till i regeared it.
Page generated in 0.23324 seconds with 41 queries
