Doubler fun (4l60 speedsensor queston) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2012, 07:35 AM   #1
Torg38
TorgFab
Torg38's Avatar
Default Doubler fun (4l60 speedsensor queston)
This doubler shit is fun I went with a spacer to correct the tailshaft spacing.(http://offroaddesign.com/catalog/700r4spacer.htm) Now I need to put in a speed sensor, I found some info that says the vss needs to be between the trans and tcase. Anyone running a 4l60 on a doubler....How did you do it?
Torg38 is offline   Reply With Quote
Old March 16th, 2012, 07:59 AM   #2
buttercr125
I work out
buttercr125's Avatar
I'm not running a doubler but my speed sensor is on the output shaft of the T-case. I just got a SYE kit from Dale at Ironman Offroad. Its the JB conversion super short SYE kit. They are the only ones that I know of that make a SYE kit with the GM speed sensor in it. What t-cases are you running? What year is your truck?
Old March 16th, 2012, 08:08 AM   #3
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
X2, usually the vss is in the tcase tail shaft housing. If you are going 203/205 I would switch the 4L60E to non-electronic or replace it with a 700r4.
Old March 16th, 2012, 08:12 AM   #4
Torg38
TorgFab
Torg38's Avatar
I'm running a LT1 with a 4l60 in a s10 chassis with four links and one tons. I issue I have is that I need a VSS to make the trans shift. If I run it after the tcases then the computer won't know that Im in low (or double low) so it won't shift out of frist gear. I need to get a Speed signal from the output of the trans to get the shift schedule to be correct. Are you running a 4L60 (or 4l80)? How does the trans act in low with the Vss being after the tcases?
Old March 16th, 2012, 08:27 AM   #5
Bleay
sick of jackstand wheelin
Bleay's Avatar
Don't get rid of the 4l60e. Use this http://www.advanceadapters.com/products/pn-716073e/
Bleay is offline   Reply With Quote
Page generated in 0.19281 seconds with 38 queries
