Connecting Rod Bearing Failure? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2012, 09:33 PM   #1
RossDickman
RossDickman's Avatar
Default Connecting Rod Bearing Failure?
Hey guys just tore into a 2001 426 yzf yamaha tonight and I thought that the piston was seized in the jug... not the case unfortunately.
Took the jug off and the crankshaft will spin a-okay but the piston is locked on to it tighter than can be... no play what so ever. There is a heat mark on the right side of the crankshaft next to the piston, but I have seen other full, complete, and functioning crankshafts with the exact same spot in the same location. That almost leads me to believing that the heat mark could be from assembly..?
Anyone hear of any similar stories or experience this themselves and know what caused the failure?
Thanks
RossDickman is offline   Reply With Quote
Old March 15th, 2012, 09:49 PM   #2
boggin-machine
boggin-machine's Avatar
the bearing is just a needle roller bearing. i have yet to see one with a problem. lets see some pics that your talking about.
Old March 16th, 2012, 08:24 AM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The 426 probably doesn't have needle bearings for the piston pin - they usually just float in the piston / rod end and get fed pressurized oil from the crank..
It sounds like it got hot / ran low on oil and seized the pin in the rod. What's weird is that the piston doesn't move on the pin. That's bad. Before replacing the rod, check the price of crankshaft kits: on some bikes a new crank/rod kits with bearings and seals costs less than repairing what you have.
@clarkstoncracker
Old March 16th, 2012, 09:37 AM   #4
RossDickman
Scooter- yeah ive done some looking around and the average price for a new "used and garunteed satisfactory" is about 300 bucks.
Boggin- Ill snap some later tonight i still need to tare er down all of the way
Thanks for the input gents
Old March 16th, 2012, 10:22 AM   #5
bdd1469
bdd
bdd1469's Avatar
Check the price on a new wisco crank with a hot rod.IIRC it was less then $300 for my 250f on thumpertalk.com
Old March 16th, 2012, 01:52 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
^^^ This is the kind of deal I was talkin' bout! ^^^
@clarkstoncracker
Old March 21st, 2012, 06:08 AM   #7
RossDickman
Correction* the rod is seized at the crankshaft - not at the piston
Making it a connecting rod bearing failure... Any other ideas? Thanks
Old March 21st, 2012, 10:36 AM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Connecting rod kit + labor to replace it.
@clarkstoncracker
Old March 21st, 2012, 10:39 AM   #9
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
http://www.motosport.com/dirtbike/oe...NKSHAFT-PISTON
@clarkstoncracker
Page generated in 0.28533 seconds with 50 queries
