Diesel build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2012, 10:33 AM   #1
Bignred23
Full Throttle
Bignred23's Avatar
Default Diesel build
Well this isn't much of a build thread seeing the truck is mostly done, but here are some pics. I bought this truck less than a month ago that was wrecked, it came with doors, and a bed already to replace the damaged parts. However the bed was rusty as hell and I didn't want to put a rusty bed on a truck from AZ. So I cut the quarter panel off and used the extra bed for the inner bed piece, then got a new quarter panel for the outer.
Now after lots of sanding and fabrication, the bed is together and on the truck. Also all the doors have been painted and are on the truck. I decided to change the color of the truck to tuxedo black in order to make the truck how I wanted.
The painting took a lot of prepping and priming to get rid of little dents, but it is finally all together and painted. Only a few touch ups needed.
Here are some build pics:
ID:	90350   Click image for larger version
ID:	90351   Click image for larger version
ID:	90352   Click image for larger version
ID:	90353   Click image for larger version
ID:	90355   Click image for larger version
ID:	90356   Click image for larger version
Bignred23 is offline   Reply With Quote
Old March 14th, 2012, 10:35 AM   #2
Bignred23
Full Throttle
Bignred23's Avatar
Final Pics, just need to replace front springs and shackles. I am putting a leveing kit on it as well. But it is almost done!
ID:	90358   Click image for larger version
ID:	90359   Click image for larger version
ID:	90360   Click image for larger version
ID:	90361   Click image for larger version
Old March 14th, 2012, 11:06 AM   #3
low900rr
low900rr's Avatar
Looks good. Is that the new ford metallic black? I did a leveling kit on mine then had to do an add a leaf in the rear to match the front.
Sent from my DROID RAZR using Tapatalk
low900rr is offline   Reply With Quote
Old March 14th, 2012, 01:35 PM   #4
Bignred23
Full Throttle
Bignred23's Avatar
Yeah that's the new Tuxedo Black that comes on Taurus' and explorer models etc. The rear end is up pretty high already, and the leveling kit isn't a spring kit, it is the stock springs with a longer shackle to let the front sit higher above the axle.
Old March 14th, 2012, 03:47 PM   #5
silveradoboy
Sam Brown
silveradoboy's Avatar
Not bad for a ford :)
silveradoboy is offline   Reply With Quote
Old March 15th, 2012, 09:27 AM   #6
Bignred23
Full Throttle
Bignred23's Avatar
Got the U-joints today, and the leveling kit also goes on today along with the FX4 springs and shocks. Also I have to wet sand and wheel it in order to complete the new paint job. It's killing me to not be able to drive the truck so it should be ready for the road tonight.
Old March 15th, 2012, 11:47 AM   #7
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Old March 15th, 2012, 02:10 PM   #8
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
Are those swirl marks on the last pic?
That was a labor of love, you must have made money at the purchase price, nice work.
Old March 15th, 2012, 02:26 PM   #9
Bignred23
Full Throttle
Bignred23's Avatar
The swirl marks are from cleaning it without wet sanding and wheeling it yet. It was painted in my garage at home so the paint needs to be wet sanded, waxed and cleaned. Pics are to come when it is nice and shiny
Old March 16th, 2012, 01:37 PM   #10
Bignred23
Full Throttle
Bignred23's Avatar
Leveling kit is on finally, along with new rancho shocks
Page generated in 0.31255 seconds with 54 queries
