5.9 Cummins. good/bad? - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2012, 12:42 PM   #41
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Originally Posted by jaysusr View Post
I knew the op bought a ford, I just figured it had blown up up by now and he was on the hunt for a new truck. Lol.
why would it blow up?
Old June 4th, 2012, 01:15 PM   #42
ajmorell
ajmorell's Avatar
C'mon Hancho, it's a 6.0 didn't you know they are all garbage...
.....obviously there has never been a single Cummins failure....
Old June 4th, 2012, 11:44 PM   #43
Christmas Cookie
ah, shit
Old June 7th, 2012, 06:57 PM   #44
88yjproject
Originally Posted by boggin-machine View Post
strange. i plow with mine....
It is just the people that don't know how to drive them when they plow.
88yjproject is offline   Reply With Quote
Old June 7th, 2012, 07:49 PM   #45
jaysusr
jaysusr's Avatar
Thsts true. But u can smoke any trans if u plow with it the wrong way.
Old June 8th, 2012, 10:35 AM   #46
Christmas Cookie
How do you plow with a truck the wrong way? I plow with mine and when I go foward I put it drive and when I back up I put it in reverse? Is there something else I should be doing?
Old June 8th, 2012, 11:02 AM   #47
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
^ Something you probably do is allow the truck to stop before shifting. Not stopping is what allot of guys do when they get in a hurry = pretty hard on the tranny...
RIP FULLSIZE4LIFE
Old June 8th, 2012, 11:04 AM   #48
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
Do you stop before you shift?
If so then you are doing it correctly.
Old June 9th, 2012, 07:20 AM   #49
88yjproject
Do whatever you want with it. It can handle it.
Old June 26th, 2012, 08:20 AM   #50
feelmeccummin
feelmeccummin's Avatar
check front end parts it will need ball joints and front ujoints around 75 to 100k. Transmissions are fine if you want to go all out put a torque converter, billet input shaft, rigid 2nd gear band, 4.2 lever and valvebody and it will take about anything you throw at it. My 03 is around is 700hp and has the same transmission for the last 80k. I sled pull and plow in the winter with it. As far as the engine injectors are about the only problem. If you notice it starting hard or a whiteish grey smoke at idle it probably has a cracked tip. For the most part they are good trucks dont listen to the haters on here just keep the mirrors down when your not pulling a trailer and for god sakes don't put a stack on it. I worked for a company that had over 30 trucks 03 to 07 all diesels and all 4x4s so I've seen about everything. They have trucks with over 500k on them
feelmeccummin is offline   Reply With Quote
Old June 26th, 2012, 09:39 PM   #51
Christmas Cookie
no you dont
Old June 27th, 2012, 08:29 AM   #52
kickstand
circling the drain
kickstand's Avatar
no you dont
I know you are but what am i
Page generated in 0.35335 seconds with 59 queries
