4l60 to np203 tailshaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2012, 04:30 PM   #1
Torg38
TorgFab
Torg38's Avatar
Default 4l60 to np203 tailshaft
So ive built my doubler and now the tailshaft on the 4l60 is too long Does anyone know what tailshaft i need? Im currently using the 4l60 4x4 shaft but it needs to be about 2inches shorter. The np203 bottems out on the splines and there is still 2.250 gap to the mating surface.
Torg38 is offline   Reply With Quote
Old March 12th, 2012, 08:26 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
If your 4l60e has the 4 bolt flange then you will need the Advanced Adapter short shaft for a 4l60e/700r4. That will give you the correct stick out length to use the t350/203 adapter and your tcase
Old March 16th, 2012, 07:26 AM   #3
Torg38
TorgFab
Torg38's Avatar
This doubler shit is fun I went with a spacer (http://offroaddesign.com/catalog/700r4spacer.htm) Now I need to put in a speed sensor, Anyone running a 4l60 on a doubler....How did you do it?
Page generated in 0.20656 seconds with 32 queries
