want to do a MAF on a 95 351W - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2012, 09:18 AM   #1
jmdzuk
jmdzuk's Avatar
Question want to do a MAF on a 95 351W
Im looking for DIY info for swaping MAF over on my 1995 351W ,not having good luck with any solid info. Any one have any real world experiance?
Thanks Jeff
jmdzuk is offline   Reply With Quote
Old March 12th, 2012, 09:33 AM   #2
Bones
Bones's Avatar
I assume auto trans?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 12th, 2012, 09:35 AM   #3
jmdzuk
jmdzuk's Avatar
yes sorry .Right now it is a bone stock 1995 Eddie Bower excab 4x4
Old March 12th, 2012, 09:39 AM   #4
Bones
Bones's Avatar
The easiet and cheapest way would be to sell your 95 and buy a 96.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 09:54 AM   #5
jmdzuk
jmdzuk's Avatar
I just bought the truck ,and your right had I known I would want /need to do a MAF I would have looked for the right truck. So is it PINTA to swap over the parts from a donner 96?
Old March 12th, 2012, 10:08 AM   #6
Bones
Bones's Avatar
I have never done that swap personally.
The biggest catch I can see would be that the 95 is OBDI and the 96 is OBDII. I don't know how putting a 96 PCM (OBDII) into a 95 truck (OBDI) would work out communication wise
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 10:12 AM   #7
jmdzuk
jmdzuk's Avatar
there seems to be alot of 302 SD trucks using the mustang MAF or Mustang SD to MAF 302 to 302..... I will have to keep digging
Old March 12th, 2012, 10:47 AM   #8
Bones
Bones's Avatar
auto trans trucks? I don't know how that would work. The PCM controls the motor and the trans. Do the mustangs come with an E4OD?
If your bronco was a manual, this would be easy. My buggy is a 1989 Bronco 351 CD motor, converted to MAF with a mustang A9L computer, but I'm running a C6 trans.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 10:57 AM   #9
jmdzuk
jmdzuk's Avatar
I wish I knew I dont want to get rid of the OD trans
Old March 12th, 2012, 11:06 AM   #10
jmdzuk
jmdzuk's Avatar
well figures I post this...continue my search to find out yes the 302 or 351 computers harness will work. But as reading I may not need or be worth the time to do the mod.....
Old March 12th, 2012, 11:24 AM   #11
Bones
Bones's Avatar
what are you hoping to gain? Why doyou think you need MAF?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 11:41 AM   #12
jmdzuk
jmdzuk's Avatar
Future Engine mods and throttle response. I will keep my eye open for a donor truck .I dont knows if there are any efficiency gains? I may not need it.. I guess
Old March 12th, 2012, 11:50 AM   #13
Bones
Bones's Avatar
unless you are planning on forced induction or a stroker kit, I wouldn't bother with a MAF swap. The reason I did it is because I eventually want to run a stroker.
I really don't think you'll see much throttle response change. I have a 94 lightning (all first gen lightnings are SD) and the throttle response on the buggy and the Lightning are basically the same.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 12:27 PM   #14
jmdzuk
jmdzuk's Avatar
Good to know thanks ,I had a Mustang (bought ) with alot of mods ran ruff needed a MAF .Just didnt wnat the truck to run into same issues. I would like to upgrade the heads and cam. and Maybe some day go to a stroker but that is way down the raod right now...
Thanks Jeff
Old March 12th, 2012, 01:58 PM   #15
Bones
Bones's Avatar
a cam swap on a SD truck will not end well. Any sort of a mild cam will require a MAF.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 02:25 PM   #16
Yotabalt
Locked In
Yotabalt's Avatar
I have swapped a 95 460 from a f250, into a 94 f350, which was originally a 351, but by far that was the easiest swap I've done, both auto trans and everything worked, but using a maf seems like a lot for a lot of nothing, I suggest just run it, when it comes time for a cam and what not, you may back out of the idea before then, and you would have blown a bunch of cash in the process lol.
Yotabalt is offline   Reply With Quote
Old March 12th, 2012, 04:55 PM   #17
frdboy
frdboy's Avatar
I did the swap on a 95, used a 302 maf truck PCM and added wires to the harness as needed. I think I had to wire the injectors different cuz they are sequential fired instead of batch.
Old March 12th, 2012, 06:42 PM   #18
s.hembree
s.hembree's Avatar
Ford Motorsport had a piggyback adapter that plugged into the ecm and then has a MAF harness coming out of it. I think I still have one laying around of you decide to do the swap Jeff.
Old March 12th, 2012, 08:02 PM   #19
Bones
Bones's Avatar
Ford racing doesn't make that harness anymore
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old March 12th, 2012, 08:20 PM   #20
frdboy
frdboy's Avatar
I think that is why I just added to the harness, couldn't find one. That was probably 5 years ago.
Page generated in 0.43303 seconds with 83 queries
