What axle is in my van? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2012, 12:25 AM   #1
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Default What axle is in my van?
I have a 1999 ford e150 with the 5.4L engine.
There is diff lube leaking out of the right rear axle tube. I would like to replace the seal and or bearing, but all the parts site only list parts for the 8.8, which I'm sure is not what I have. It's much bigger. So what is it? How do I get the right parts?
Old March 12th, 2012, 12:39 AM   #2
bigjeep
bigjeep's Avatar
Default axle
If the whole 3rd member in bolts its a 9" other wise it may be a 10.25 . I had a 1995 e150 and while it was much larger it was still a 8.8 . There should be a tag on the bolts for the cover. Or I believe some times they stamped it on the axle tubes. Good luck.
bigjeep is offline   Reply With Quote
Old March 12th, 2012, 05:16 AM   #3
skife
skife's Avatar
take pics of it, its probably an 8.8
Old March 12th, 2012, 07:52 AM   #4
brewmenn
brewmenn's Avatar
It's not 9" and it looks nothing like the 8.8 I have in my Jeep.
Old March 12th, 2012, 08:03 AM   #5
cj65
cj65's Avatar
For sure not a 9"'production stopped on these rearends in the late 80's. Most likely a 8.8 hd. That's what most vans have.
Old March 12th, 2012, 08:09 AM   #6
kkodet
kkodet's Avatar
It could also be a semi float dana 60, several of my dad's E vans (contractor models) have them.
Old March 15th, 2012, 08:53 AM   #7
bigblocked
bigblocked's Avatar
Almost positive it's a 9.75".
bigblocked is offline   Reply With Quote
Old March 15th, 2012, 10:53 AM   #8
Coyote Red
Coyote Red's Avatar
Have you tried to look up what the code under "Axle" on the door translates to?
Coyote Red is offline   Reply With Quote
Old March 15th, 2012, 11:15 AM   #9
booblinker
Sore and Tired 24/7
booblinker's Avatar
In the F150 they put 8.8 or 9.75, maybe someone swapped in an f150 9.75?
Old March 15th, 2012, 01:31 PM   #10
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Here the options I see for a 150.
E150, (3.55 ratio), 8.8" ring gear
E150, (3.55 ratio), 9.75" ring gear, tags S710D & SPM710D
E150, (3.55 ratio), 9.75" ring gear, tags S711D & SPM711D
E150, (3.55 ratio), 9.75" ring gear, tags S710A & SPM710C
E150, (3.55 ratio), 9.75" ring gear, tags S711A & SPM711C
Page generated in 0.31183 seconds with 53 queries
