Polishing Aluminum wheels? get the grey out? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2012, 06:51 PM   #1
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
Default Polishing Aluminum wheels? get the grey out?
I'm polishing up a set of aluminum wheels, I started with 00 with polishing compound, moved to 0000 steel wool and water, the finish is smooth, but how to get the dark grey color out and make them bright shiny? tips?
Trying nev'r dull too, but there's gotta be a "right way"
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old March 10th, 2012, 07:23 PM   #2
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I've used Mothers and the powerball on a drill with pretty good success.
Sent from my Non-Apple product using Tapatalk.
Cheap Thrills Off Road
Old March 10th, 2012, 07:30 PM   #3
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Power ball ftw.
Silver Bullet is offline   Reply With Quote
Old March 10th, 2012, 07:32 PM   #4
03hemisilver
Like the Lotto?
Old March 10th, 2012, 07:35 PM   #5
Silver Bullet
Fawk the lotto .
Old March 10th, 2012, 07:36 PM   #6
03hemisilver
Fawk u
Just teasin' Drinkin' watchin' Lizard Lick Towing Marathon tonite
Old March 10th, 2012, 07:48 PM   #7
IDIeselman
IDIeselman's Avatar
http://www.metalwax.com/videos.html
The best and easiest I have found.
Old March 10th, 2012, 07:56 PM   #8
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
This stuff, but you have to use it the old fashion way for best results.
Old March 10th, 2012, 09:17 PM   #9
Silver Bullet
LOL Lizard lick. Watching contagion
Old March 10th, 2012, 09:50 PM   #10
blade262us
blade262us's Avatar
Default Aluminum polish
simichrome works very well .
http://www.amazon.com/Simichrome-Pol.../dp/B000BGOC0W
blade262us is offline   Reply With Quote
Old March 10th, 2012, 09:54 PM   #11
chevy_4x4_trucks
chevy_4x4_trucks's Avatar
Originally Posted by wadey View Post
this stuff, but you have to use it the old fashion way for best results.
just used this on my rims and i cant believe how nice they turned out...just took alot of elbow grease
chevy_4x4_trucks is offline   Reply With Quote
Old March 11th, 2012, 10:00 AM   #12
BigBird
BigBird's Avatar
Originally Posted by Silver Bullet View Post
Power ball ftw.
Originally Posted by 03hemisilver View Post
Like the Lotto?
Google Mothers powerball... I guess if you won the lottery you could buy new rims and screw the elbow grease....
Old March 11th, 2012, 11:31 AM   #13
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Originally Posted by blade262us View Post
this is what i use at work on all small and large aluminum parts
Old March 11th, 2012, 11:57 AM   #14
stereoguy
2jz NO SH*T!
stereoguy's Avatar
Simichrome is the shit! A lot less elbow grease too!
stereoguy is offline   Reply With Quote
Old March 11th, 2012, 12:16 PM   #15
cerial
Direct Drive FTW
cerial's Avatar
I used Meguiars Hot Rims Mag and Aluminum Polish in March and then July every year. After shooting the rims and wiping off the break dust. Remove the tire/rim and apply a small dab rub that on the outside and let it sit. While your cleaning and polishing the inside the inside the outside will turn darker. Simply remove most of it and you will end up with a very shiny rim for months.
I rip up t shirts instead of using a ball. I can remove a lot more grime and grit with the t shirts instead of constantly cleaning and re using the ball.
I have tried blue magic and mothers before on rims they work ok. Fritz and never dull are a joke. Meguiars is my choice for rims. I do prefer Mothers to wax the interior over Meguiars though.
Just my .02
Old March 11th, 2012, 01:37 PM   #16
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Here's what I do. I use latex/nitrile gloves instead of a rag since they soak up all the compound and glaze over too much. I swipe my fingers through mothers or whatever soft stuff I'm using and start rubbing till the stuff turns black and keep going adding fresh polishing compound as I go. Read up on how aluminum polishing stuff works and it makes sense. After I have the whole rim done, I go back over with a microfibre cloth to final polish/clean the rims and wallah! Its a bling fest.
Mulely is offline   Reply With Quote
Old March 11th, 2012, 01:39 PM   #17
Mulely
Mulely's Avatar
By the way, Mother's Billet polish is awesome, just expensive to use a lot. 3M has a metal polish I'll use with a cotton buff when I need to really move some oxidation.
Old March 12th, 2012, 03:39 PM   #18
dline
dline's Avatar
http://www.ebay.com/itm/Wizards-Meta...item3371d19e0b
dline is online now   Reply With Quote
Page generated in 0.30556 seconds with 77 queries
