help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2012, 02:09 PM   #1
madeforspeed
madeforspeed's Avatar
Default help
i just replaced my 2.9 in my 87 ranger because it had a rod knock and i got new moter in and there is no fuel to the rale but you can hear the pumps kick on and there is almost half tank in the truck what could it be
madeforspeed is offline   Reply With Quote
Old March 10th, 2012, 04:41 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
most likely a kinked line if there's suddenly no fuel.
Is it not firing the injectors? or is there truely no fuel getting to the line? (you bled the fuel rail with the tire valve looking thing right?)
Old March 14th, 2012, 09:47 PM   #3
madeforspeed
Default fuel
i not getting gas to rail at all but pumps kick in would it be the fuel pressher regulator
Old March 14th, 2012, 09:51 PM   #4
GREASYHANDS
GREASYHANDS's Avatar
Are you sure your injectors are firing?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old March 15th, 2012, 12:11 AM   #5
Captain Ledd
Ranger Addiction?
If no gas squirted out of that bleeder valve and you're positive the pump is turning on and pumping, you have either a blocked line, or a kink in the line. Most likely a kink or somewhere accidentally got crushed shut.
You can rent injector test lights at Autozone. They plug into the fuel injector connector and has a little light that will flash when the injector gets the electrical signal to fire.
Seriously, go over your fuel lines from the rail to the tank.
Old March 15th, 2012, 01:24 PM   #6
madeforspeed
Default fuel
i pulled of line at rail and it shoots gas but none to rail
Old March 15th, 2012, 01:31 PM   #7
Bones
Bones's Avatar
your sentance makes no logical sense. Please try again.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 15th, 2012, 02:11 PM   #8
kevinr839
kevinr839's Avatar
Sounds like the injectors are not firing. Did you try removing an injector from the rail and see if fuel comes out there? If no fuel comes out i would think regulator. If fuel comes out i would look for a missed ground or something.
kevinr839 is offline   Reply With Quote
Old March 17th, 2012, 01:11 AM   #9
madeforspeed
Default ..
the line that goes in the fuel presser regulator when i pull it of it shoots out gas but don't push it though the regulator and in to rail and i replaced the regulator what could it be and if any one can get me a vacuum diagram for a 87 ranger 29v6 would be great thanks.
Page generated in 0.24993 seconds with 50 queries
