The KRAKIN build thread - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2012, 11:12 AM   #1
sandman101
Default The KRAKIN build thread
Well being as i've been sick to the doctor poked and xrayed all week i decided i might as well make a build thread of "unfinshed" project truck. I bought the truck back in 07 when i lived in Wyoming. As you will see in the pic's i post it looked as if it came straight out of Mexico when i first got it.
The truck is a 1997 Cheverolet k1500 4x4.
5.7 vortec, Completley rebuilt 4l60e, 241 transfer case.
Came with the 8.25 Ifs front and 10 bolt rear axle.
The first week i bought the truck i bought some 33 BFg A/ts and used some 15 inch alloy wheels my cousin gave me. Talk about stuffage.
About a year after that i was into the blingy crap and tossed on a 6 inch rough country rcx lift and all the chrome stick on's autozone had.
sandman101 is offline   Reply With Quote
Old March 10th, 2012, 11:16 AM   #2
sandman101
After this point i sold of the wheels and tires and put some fresh torsion bar's from a 2500hd and some 37x14 irok's on 15x12 wheels i got from Unlimited Offroad and removed the horide tail light's.
I was pretty happy with this look and content for a while until i kept breaking front end part's.
Old March 10th, 2012, 11:21 AM   #3
sandman101
This bring's up to what i consider the actual "progress" of building a all purpose full size.
I ditched the IFS and went to straight axle with crossover steering. I got a good deal from Unlimited offroad and bought my leaf springs, braket's, and the 79 hp dana 44 from them.
I started gutting all the IFS componet's from the front and sold them along with the irok's.
Old March 10th, 2012, 11:26 AM   #4
sandman101
Had my passenger side steering tapped and threaded for my crossover steering arm.
I then started the assembly and moking up of the front axle and steering setup.
For the steering setup i used DOM and 1 ton chevy tre bung's and the 1 ton tre's.
Got the front end to pretty much wrapped up other than the ring and pinion and gears.
Old March 10th, 2012, 11:30 AM   #5
sandman101
For the tire's i decided to go with the 37" BFgoodrigh km2's which i am supposed to sell to thrill20 but haven't had time to get them pulled off yet.
The shock's i went with are the Bilstein 5150 shcoks.
Nice reservoir shock for the price.
Old March 10th, 2012, 11:42 AM   #6
sandman101
This brings me to the rear axle. I decided to go with the 14ff for the price and strenght. It seemed like a no brainer for me. I picked one up in Clare for a great deal with disc brakes already swapped on it. However i did end up grinding the perches off as the older chevy's are 42" and 88-98 is 47" widths. So i pulled out the grinder and went to work.
I also swapped the lug bolt's out for some for a dually for extra lenght as the originals didn't leave much room for thread's on aftermarket wheel's.
Old March 10th, 2012, 11:45 AM   #7
sandman101
I also decided for the rear suspension to ditch the 4" block and do a shackle flip and change the stock "tin" shakle for a more stout 6" long one. This setup netted me roughly 4.5 inches of lift in the back. I then added a zero rate and 1" add-a-leaf also.
Old March 10th, 2012, 11:48 AM   #8
hondadirtracer
Skymaster
hondadirtracer's Avatar
You are more than welcome to drive it to Kalamazoo and leave the keys and the signed title in it. I promise I will take good care of it.
hondadirtracer is offline   Reply With Quote
Old March 10th, 2012, 11:49 AM   #9
sandman101
This pretty much bring's me up to the current status of the build. Still isn't finished and it's way to big because i haven't removed the body lift yet but it's coming along and i'm pretty happy with it.
Old March 10th, 2012, 11:52 AM   #10
sandman101
I have'nt even finshed it yet though. Can't i atleast finish the build first?
Old March 10th, 2012, 11:59 AM   #11
hondadirtracer
Skymaster
Be my guest lol. I don't think I would be able to finish it in the campus parking lot.
Old March 10th, 2012, 12:01 PM   #12
Elusive
Elusive's Avatar
Nice job. Looks great!
Elusive is offline   Reply With Quote
Old March 10th, 2012, 12:34 PM   #13
honda rider
Beaver Patrol
honda rider's Avatar
that's BA...nice work
honda rider is offline   Reply With Quote
Old March 10th, 2012, 12:38 PM   #14
boggin-machine
boggin-machine's Avatar
Truck looks good bud! I still love these trucks. I'd love to build another quad can if I could find one anymore.
Gotta be one of the cleanest around here still
Old March 10th, 2012, 05:42 PM   #15
Elusive
Elusive's Avatar
I agree. I use to have a 97 chevy z71 with a 5.7 and i'd take that motor over my current 5.3 for towing any day. Best truck i ever owned.
Old March 10th, 2012, 11:19 PM   #16
ayytee
all throttle no tallent
I'm getting ready to sas a reg cab shortbox with the skys 2 1/2 brackets and some 2.5 springs. What are you running for front leafs? looks like there might be a zero rate in there too? Trying to keep mine as low as possible on a 35-37 inch tire.
ayytee is offline   Reply With Quote
Old March 11th, 2012, 08:23 AM   #17
sandman101
I'm running the ORD 3" braket with a 4" lift spring, and a 1" zero rate. I moved the axle forward a 1" also and figure it should sit nicely once the body lift is out.
Old March 11th, 2012, 10:16 AM   #18
Offroadian
seasoned
I think it'll look sweet once the body lift is out.
Offroadian is offline   Reply With Quote
Old March 11th, 2012, 12:16 PM   #19
sandman101
Thank's. I might even run 39" Krawler's on it once i swap to a dana 60 hydro assist. I've got some other plans i'll toss in now. Any suggestion's on the sheet are welcome. I'll post them high to low priority.
Panhard bar
Remove body lift
Custom front and rear d-shaft's
4.88 Yukon gear's
Ziplocker in rear
Chromoly shaft's in front
Hydro boost
Custom PCM tune
Fix heater motor and interior driverside door handle
Rebuild my free Warn 9k winch.
Custom low profile front and rear bumper's with winch mount's f+r
Build either a tiregate or some way to mount matching spare while keeping bed space.
Dual batteries
2 8" fog light's
2 6" running light's
2" rear wheel spacer's to make track width same as front
Rock slider's
Change steering box for hydro assist
Hi lift jack
Bumpstop's all around
Old March 11th, 2012, 09:57 PM   #20
Red97
Just tap the cap and top plate for hydro assist. Thad is what i did on my 97 sas It steers great now. It has been fine for the last year driving it every day.
Red97 is offline   Reply With Quote
Page generated in 0.37207 seconds with 84 queries
