Homemade Tcase Cable Shifter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2012, 11:09 PM   #1
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Default Homemade Tcase Cable Shifter
Ok I'm swapping in a 231 and I have a few questions regarding building my own cable shifter.
For the cable,
Would a universal push pull cable be up to the task? Or should I look for something else?
For the shifter itself,
How much mechanical advantage should I build into it to ensure easy shifting?
How important are gates and stops, relating to finding all the ranges?
Are the detents in the case strong enough to hold a gear without support? Or are gates required for holding a gear?
Pictures and any suggestions would also be appreciated, thanks
Old March 9th, 2012, 11:17 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
whats it going in? My 95 S-10 has a cable style shifter for the t-case. you could try and find one just like it.
Old March 9th, 2012, 11:29 PM   #3
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Its going into my 99 blazer. The problem is that I have a 5 speed and unless I can find a floor shifter out of a s10 with a stick the center console wont work.
Old March 10th, 2012, 08:25 AM   #4
cerial
1200PSIg Double acting
cerial's Avatar
Originally Posted by wadey View Post
For the cable,
NO
Ultralight/Aircraft cable you get great quality for your $$$.
Old March 10th, 2012, 08:36 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
mines a 5 speed too. i would sell you mine but idk how im going to do my twin stick setup for my 205 yet.
Old March 10th, 2012, 08:37 AM   #6
mudrunner456
mudrunner456's Avatar
i have cut the gates out of my truck and my jeep. no problem holding gear and as long as you know what you are doin finding the gear is easy. why not build real linkage instead of using cable. never done it but cant be to hard to figure out.
mudrunner456 is offline   Reply With Quote
Old March 10th, 2012, 09:57 AM   #7
Bones
Bones's Avatar
you're going to want a heavy duty push/pull cable.
When I did cable shifts on my previous projects, I used cables from Midwest Control with really good results.
http://www.midwestcontrol.com/part_family.php?id=3
1/4 - 28 is about the minimum size I would use. The disadvantages to going larger are; 1- they won't bend as easy 2- they cost more
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 10th, 2012, 08:52 PM   #8
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I plan on doing this sometime this month so if your ready by then let me know.
So I can place the shifter where I want it without a overly complicated linkage setup.
Thanks for the link and size info. Did you order your cables with 3" or 4" throw?
Old March 12th, 2012, 06:28 PM   #9
Bones
Bones's Avatar
That all depends on the throw of your shift rail on your Tcase. A 3" works fine on transfer cases that have twin rails (like an D20, D300, Atlas, etc). I have no idea what a 231 looks like or how it shifts, so you'll have to measure for yourself.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 18th, 2012, 01:53 PM   #10
Bad Zuk
Here is info from a post I stumbled across a while ago, I haven't bought anything, I just made my own linkage instead. These are part #'s from McMaster Carr I believe.
1338K21 Low Friction Threaded-Mount Push/Pull Cable 1/4"-28 Threaded Ends, 4' Overall Length (x2)
6071K12 Forged Steel Clevis Rod End 1/4"-28 Female Thread Size, 2" Length (x2)
90264A440 Grade 2 Zinc-Plated Steel Coupling Nut 1/4"-28 Screw Size, 7/8" Length, 3/8" Width (x2)
These are parts that someone used to build a cable shifter for a 205 I think.
Bad Zuk is offline   Reply With Quote
Page generated in 0.23056 seconds with 53 queries
