Drill press suggestions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2012, 09:12 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default Drill press suggestions
Looking to buy a drill press to add to my tool collection. Can i get away with a HF model, or should i stick to name brand models? price range is less then $300. This will mainly be used for drilling metal, i'm not sure if a 5 speed will work or should i look at more speeds?
Old March 9th, 2012, 09:32 PM   #2
rentalrider
rentalrider's Avatar
I like the grizzly model.
Sent from my DROIDX using Tapatalk
Old March 9th, 2012, 09:50 PM   #3
Some of the better HF ones aren't too bad. # of speeds isn't as important as RPM. YOu want to be in the low 100's, like 120 or 140 rpm.
Honestly, the HF one I have almost never gets taken off that lowest speed. It has done fine for 7 or 8 years.
I will say this, though, I have a mill now, also, and that does my drilling these days. Haven't chucked a bit into the HF one for at least 2 years. The difference in runout and rigidity are night and day. The HF drill chatters a good bit. You never get nice spirals of metal when using the big twist bits. Same bits in the mill will make perfect spirals of razor thin steel. The chucks aren't very good on the HF one either, they like to loosen up.
But, that said, the HF works decent for a basic press.
Old March 9th, 2012, 10:00 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i wish i had the $$ for a small bridgeport. i could have a field day with one of those. as i have been pricing and comparing drill presses for the past few hours i've noticed most of the inexpensive models appear almost identical in specifications and appearance. make me wonder if they aren't all made in the same plant with different names put on them.
Old March 10th, 2012, 07:03 AM   #5
What Jesus said. I have a Delta drill press, bought originally for mostly wood working. I still use it a lot for simple things since it's easier to put a big piece on the flat table and move it around easier than the Bridgeport. BTW, there really isn't a "small" Bridgeport. I think the smallest is a 36" table. If you're going to go to the effort to get one, I like the larger table better.
Old March 10th, 2012, 07:13 AM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
tsc has some good ones
H.o.r.e
Old March 10th, 2012, 10:39 AM   #7
Bones
Bones's Avatar
there are usually a bunch of drill presses on craigslist. People must buy them for a project and then never use them for 3 years and sell them.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 16th, 2012, 10:47 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well ended up getting one from harbor freight. hate china made shit but i can't find a better deal to suit my needs. ended up paying 180 out the door for the 16 speed floor model. assembling it was a piece of cake, but i found out the crank system for the table needed work. the gears inside have no washers or anything between them and the housing, so i installed 2 washers on the handle gear, then packed the inside of the housing with grease. goes up and down smooth as can be. just tried the drill out, and with a 3/8 bit i got through a 1/2 piece of bar stock in no time on the 720 rpm setting. i think i'm going to make a drip oiler though as metal cuts better with lubrication.
Page generated in 0.17729 seconds with 47 queries
