Startin custom tube crawler.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2012, 06:08 PM   #1
cjh4676
cjh4676's Avatar
Default Startin custom tube crawler..
Starting a new bulid finally, tube frame, four link, toyota running gear, 350 chevy with 350 turbo trans runnin on propane, 38.5 boggers and its gonna be a two seater i have a few questions before we get goin on this fram (were drawing it up this week) what do you think the best wheel base is from crawling with the tire i got and do u think i can run 2.0 Fox Air shock or do i need to run 2.5 Fox Air shocks?
cjh4676 is offline   Reply With Quote
Old March 9th, 2012, 08:06 PM   #2
knixon804
THE GENERAL
knixon804's Avatar
wheel base is up to you. i take it your truck is a ext cab as in your avatar? id leave the wheel base stock. (easy for using stock length driveshafts) as for your air shocks, are you just crawling or more? 2.0s are ok and will flex really good but cant hold a bunch of weight. id go with 2.5s
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old March 10th, 2012, 05:59 AM   #3
He said it was going to be a new tube frame. Therefore, there is no stock length. Anyway, if you are going to stick with the 38.5 boggers, which are about 36" tall, I'd shoot for 100-104" wheelbase. Maybe a tad shorter. However, if you plan on upgrading tires to the 39-40" range in the future, I'd go 106-110". I'm 104" and wish I was a little longer. If it's truly a tube frame, go with the 2.0" air shocks.
Old March 10th, 2012, 06:18 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
im 113 with 38.5s and i think it sits and works well
H.o.r.e
Old March 10th, 2012, 06:18 AM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
yah and 2.0 shocks will be fine thats what i run also
H.o.r.e
Old March 10th, 2012, 08:21 AM   #6
alumcj
alumcj's Avatar
Anything will work for crawling if you tune them. I've run both sizes. If you plan on bombing trails, I'd go coil overs. No comparison in the comfort area, but a lot more scratch.
alumcj is offline   Reply With Quote
Old March 10th, 2012, 08:24 AM   #7
bigbchevy
missmrgreenagain
bigbchevy's Avatar
true dats
H.o.r.e
Old March 10th, 2012, 01:18 PM   #8
cjh4676
cjh4676's Avatar
Ya its going to be a full tube cage and i saw the 2.0 hold 550lbs each and 2.5 are about 1200 lbs i think im gonna just go ahead and run the 2.5 spend the extra 400 a pair. When heim joint do u guys recommend its shouldnt way over 4k and just running a stock 350 on propane may get torque cam later ive been told 7/8 would be fine i have some 3/4 chromoly at the house could i use those all the way around or just for the top links and get 7/8 or 1 inch for bottom???
Old March 10th, 2012, 01:19 PM   #9
cjh4676
cjh4676's Avatar
and im gonna run a 102 wheel base.
Old March 10th, 2012, 04:44 PM   #10
BIG_BLAZER86
BIG_BLAZER86's Avatar
1.25 heims
BIG_BLAZER86 is offline   Reply With Quote
Old March 10th, 2012, 04:50 PM   #11
cjh4676
cjh4676's Avatar
would it be alright to run the 3/4 chromoly ones i have now for the top links?
Old March 10th, 2012, 05:08 PM   #12
cerial
Direct Drive FTW
cerial's Avatar
Do you plan on putting the drive train between the axles to drop your COG?
Old March 10th, 2012, 08:04 PM   #13
cjh4676
cjh4676's Avatar
trans and transfer will be up under the seats close to it
Page generated in 0.23807 seconds with 62 queries
