1999 Dodge Stratus - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2012, 01:02 PM   #1
Till_Winter
BRAAAAAAAAP
Till_Winter's Avatar
Default 1999 Dodge Stratus
Im selling my 99 dodge Stratus, It has a 2.4 litre 4 cylinder motor. The car has around 153,000 miles on it. Its a good gas saving car, It has cruise control and power windows. Heat works good. The A/C does not work. In the past year i have replaced the front 2 wheel bearing on the car, one rear wheel bearing, one upper ball joint and a fuel pump. It has new front tires. The rear tires are bald. The ABS light is on. The only real problem with the car is it leaks a decent amount of oil. It has a high pitched noise that comes from under the hood, the noise comes and goes. Its been like that as long as i have had the car. And it also needs new sway bar end links. The car has some bad rust in spots and some small dents. It has a touch screen JVC radio in it that i will let go for the right price, If not then i will put the stock radio back in it. Over all it is a good running and driving car. Im selling the car as is. Im asking $1,100 O.B.O Cash only! You can contact me at 734-637-3862 call or text, If i dont answer leave a message and i will get back to you A.S.A.P
ID:	90152   Click image for larger version
Till_Winter is offline   Reply With Quote
Old March 10th, 2012, 01:56 PM   #2
Till_Winter
BRAAAAAAAAP
Sold
Page generated in 0.13093 seconds with 30 queries
