dadsmudrun 2012 season dates - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old March 8th, 2012, 01:56 PM   #1
dirty addiction
dirty addiction's Avatar
Default dadsmudrun 2012 season dates
dates for dadsmudrun
june 16
july 21 points race
sept 15
classes and more info soon
also going to be some more improvements to pit and pit area
going to be a exciting season hope everyone is getting ready!!!!!
dirty addiction is offline   Reply With Quote
Old March 8th, 2012, 05:56 PM   #2
mudrunner456
mudrunner456's Avatar
how are your classes set up?
mudrunner456 is offline   Reply With Quote
Old March 12th, 2012, 11:14 AM   #3
dirty addiction
just like the westmichiganmudruns pionts classes but we might have a street class and tractor tire class on top of are class 1 though 7 i will get them posted here soon thanks.
Old March 12th, 2012, 11:16 AM   #4
dirty addiction
General Truck Rules
Solid tow out point (Each and every driver MUST pull a cable)
Helmets and seat belts required by all vehicle occupants
Fire Extinguisher on board
GOOD SPORTSMANSHIP is required or you will be asked to leave!
$20 one time entry fee per driver, per truck, per class
Classes and Rules
Class 1 36.5" DOT (non cut) tires and under
4x4 vehicles only-production type frames and suspension
Any motor drive train combination
Front of motor can not be behind center line of front axle
Body swaps allowed with motor in stock location of frame, axles within 6" of center of wheel well
Flat beds and gutting allowed, must maintain stock appearing bodies (not homemade)
Must have doors, hood, and firewall. Replacement fiberglass body or parts ok
Single carb, gasoline only, no nitrous
No aluminum heads or aluminum blocks permitted
Vehicles with factory support of cab cut, or glass removed, open or soft tops MUST have roll bar to the frame
Passengers allowed at the discretion of the track owner
Maximum engine size 514 cubic inches
Class 2 44" DOT (non cut) tires and under
Same rules as class 1
CLASSES 1 AND 2 ARE MEANT FOR LOWER BUDGET BEGINNERS, IF YOU SHOW UP WITH HIGH DOLLAR MOTOR TO RUN THOSE CLASSES, YOU WILL BE BUMPED UP TO CLASS 3 AND 4
Class 3 36.5" DOT (non cut) tires and under
​4x4 vehicles only-production type frames and suspension
Any motor and drive train combination
Body swaps allowed
No aluminum blocks permitted
Aluminum heads allowed- conventional type only
Engine set back should be no more than 12" from centerline of axle to #1 spark plug
No aluminum hubs
No nitrogen shocks
No fiberglass or carbon fiber springs allowed
Wide five wheels are ok if they are used with an adapter, no wide five hubs
Class 4 44" DOT (non cut) tires and under
Same rules as class 3
Class 5​ 39.5" DOT tires and under
Cut DOT tires allowed
2"x3" square tube frames ok
4 link and other adjustable suspensions allowed
Engine must be in front of driver
Fiberglass bodies ok, no full fiberglass racing bodies
Max deck height Ford-10.320 GM-10.200 Chrysler-10.72
Alcohol through carb, no injection
Any enclosed transfer cases
Gutting allowed
Must be naturally aspirated
​Small blocks can run a 300 shot of nitrous, iron headed big blocks can run a 250 shot of nitrous
​FIRE SUITS REQUIRED!!!
Minimum four point harness
Roll cage requirements: 6 point minimum, with 4 points to the frame. .090 min thickness 1 5/8 min. on main support
Master kill switch within driver's reach with an exterior kill switch on right rear of vehicle
Maximum wheel base of 150"
Wide five wheels ok
NO PASSENGERS!!!
Class 6 54" DOT tires and under
Same rules as class 5
Class 7
ANYTHING GOES!!
Paddles and tractor tires ok
FIRE SUIT REQUIRED
NO PASSENGERS
Minimum 4 point harness
Roll cage requirements: 6 point minimum, with 4 points to the frame. .090 min thickness 1 5/8 min. on main support​
Old March 12th, 2012, 11:21 AM   #5
dirty addiction
there may be a street class and a tractor tire class at are place also if we do a tractor tire class, four tractor tires are needed to run class. this class may end up as a heavy hitters class for the bigger heavier trucks or just a tractor tire class i will let you no when it gets closer and i get more feedback . also we will try doing a street class before class 1 but it may be alliminated depending on truck intries.
Old March 12th, 2012, 11:27 PM   #6
dmcjeep
dmcjeep's Avatar
This intrigues me?
Don't they kind of contradict each other. How much does it cost to get 514 CI?
dmcjeep is offline   Reply With Quote
Old March 13th, 2012, 07:25 AM   #7
IDIeselman
IDIeselman's Avatar
Originally Posted by dmcjeep View Post
This intrigues me?
About $2000 for a drop in kit.
New 4340 forged steel 4340 crankshaft, Standard weight, 2pc rear main seal
New 4340 forged steel H beam connecting rods with ARP 8740 7/16 rod bolts
New JE 2618 forged pistons, with wrist pins and spirol locks
New Performance Ductile Iron Plasma-moly piston ring set
New Clevite 77 / ACL rod and main bearing set.
little cheaper if you go with an offset ground factory cast crank and source rods, pistons from various builders. Not much of a price difference from a standard rebuilder kit to a stroker kit.
A 514" is an economical stroker build with tons of torque. Re-use your stock crank and have it offset ground, add a set of off the shelf pistons and rods, a 514" is born. For close to the same price a guy could cheat and drop in a 557" kit, no machining required other than cylinder boring.
Old March 13th, 2012, 10:53 AM   #8
4-PLAY
4-PLAY's Avatar
From what i heard, if you run good or win in class 1 and 2, you will be bumped into class 3 and 4 next race. Its for stock and first time racers.
4-PLAY is offline   Reply With Quote
Old March 13th, 2012, 11:05 AM   #9
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
What if i am a first time racer, but have a 514? lol jk, i aint got the money for that. But this sure sounds like a lot of fun. Might have to stop out.
XLJetsFan52 is offline   Reply With Quote
Old March 13th, 2012, 11:09 AM   #10
dirty addiction
the goal this season is to keep the classes as fair and competitive as we can if you can't find a class that fits your rig this season at any of the west michigan races and or crc then maybe comp running isn't for you we will have techs at every race points and non points to try and keep thre rigs running in the right classes looking forward to a get season of racing and i hope these classes will bring back all the rigs in are area and new guys to race!!! always incourage new faces and places!!!
Old March 13th, 2012, 02:45 PM   #11
dmcjeep
dmcjeep's Avatar
I assume this is if you start with a 454?
Old March 13th, 2012, 03:21 PM   #12
dirty addiction
he's talking bbf power denny!!!
Old March 19th, 2012, 10:44 AM   #13
dirty addiction
we were out back sunday doing some more clearing making somemore parking had a couple rigs out testing and tuning love the smell of racing fuel in the air getting excited again!! we are moving mud pit back 20ft or so to make more shut down area and improve spectator veiwing this will also give us more room for pitside parking by moving the fence line further out tords staging area witch everyone noise we need!!
Old May 11th, 2012, 02:29 PM   #14
dirty addiction
we will be out back this weekend putting up some more gaurd railing june 16 will be here before we no it.
Old June 4th, 2012, 01:10 PM   #15
dirty addiction
everything is looking great out back almost ready for first race we will have some new concessions out there june 16 anything from chicken, corn dogs, hotdogs, sloppy joes, elephant ears and more two kids foot races raffles and plenty of mud for everyone.
Old June 4th, 2012, 01:16 PM   #16
dirty addiction
class for are june will be
street class 35 down must be streetable rig with exhuast mild motor up grades factory suspension lift kits ok.
class1though 7 are same as westmichigan point classes
and class 8 will be a heavy hitter class 2.5 ton and bigger axles any size tire .
if i don't get enough big rigs out for this run this class will change into some type of a tractor tire class.
Old June 10th, 2012, 09:13 AM   #17
Unemployed Films
Capturing 4x4 Moments
Unemployed Films's Avatar
Come on out for a fun filled day for the entire family. Always a fun time at Dad's Mud Run.
Unemployed Films is offline   Reply With Quote
Old June 11th, 2012, 11:03 AM   #18
dirty addiction
ok guys and gals we are trying something new for entry to the back there will be two entrance points off road one for spactators is the original drivway going back and mud trucks and trailer will be useing main driveway and useing the exit drive to the pit area as there drive back to pits. any questions let me no thanks.
Old June 14th, 2012, 09:09 AM   #19
dirty addiction
ok change of plans we will be useing the normal drive for everyone to enter out back and keeping the pit exit drive just that for now. hoping for july to have it changed around but just not enough help to make it work this run
Old June 17th, 2012, 01:51 PM   #20
dirty addiction
Thank you to everyone that came out . It was a great day
Page generated in 0.46993 seconds with 84 queries
