What the lowest load on heims i should use for a tube cralwler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2012, 08:36 PM   #1
cjh4676
cjh4676's Avatar
Default What the lowest load on heims i should use for a tube cralwler
Making a buggy with a four link system i was wondering what load size heims i should use for the four link system?
cjh4676 is offline   Reply With Quote
Old March 5th, 2012, 08:39 PM   #2
cjh4676
cjh4676's Avatar
can you run aluminum ones or will they break to easy?
Old March 5th, 2012, 08:47 PM   #3
Tab
Tab's Avatar
A good 3/4 rod end has about a 76k radial load rating. But the bigger issue is the shank bending/breaking. Why do want the weakest you could use when you could just get the size that works best and is safest?
Old March 5th, 2012, 09:19 PM   #4
Bones
Bones's Avatar
Exactly what tab said. i would recommend a 3/4" bore witha 7/8" shank
buy these.
http://www.ruffstuffspecialties.com/...g/78x34RE.html
I think he even offers a greatlakes4x4 discount.
EDIT- this is assuming you are building a tube rig under 4500 lbs and under 450 hp. If this is a 600hp rig on rockwells, you'll need bigger. I just saw you are from TN, and there are some big rock rods down there.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 5th, 2012, 09:26 PM   #5
cjh4676
cjh4676's Avatar
well i just moved to tn and its gonna be a tube buggy with toyota running gear 350 chevy and 38.5 boggers
Page generated in 0.27455 seconds with 38 queries
