92 bronco ttb vs sas? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2012, 12:13 PM   #1
foxworthy1102
foxworthy1102's Avatar
Default 92 bronco ttb vs sas?
I'm considering doing a sas on my bronco. I haven't put a lift on it yet and will probably be spending more time on the road than off? Would it be worth my time and $ to put in a Dana 60 or just stick with the stock ttb?
foxworthy1102 is offline   Reply With Quote
Old March 5th, 2012, 06:36 PM   #2
Never_Evil
If you are lifting and putting big tires on, stick with stock.
Old March 27th, 2012, 08:18 PM   #3
Jager
Inspector
Jager's Avatar
If you like bouncing down the wash board and pot holes sideways, install a SAS front end. SAS for heavey rock climbing, TTB for that and everything else. Way better ride and handling with TTB front end.
Jager is offline   Reply With Quote
Old March 28th, 2012, 02:28 PM   #4
Coyote Red
Coyote Red's Avatar
Dana 60 about 800-1000+ dollars, if you can find one that is still there when you arrive, and then you have to get radius arms, shocks, springs, and steering.
BDS TTB lift, 1300 or so and you just remove bolts and install. Other kits range from 500 up.
If you will be spending most of your time on the road just keep the TTB.
Coyote Red is offline   Reply With Quote
Old March 28th, 2012, 09:29 PM   #5
masterbeatty
masterbeatty's Avatar
or do a dana 44 from a 78 79 f150, the ride will be ten times better than the ttb, wont have to worry about alignments and wearing tires funny. look up fullsizebronco.com lots of good info there. i have had a few sas broncos i dd and i have always prefered the ride.
Old March 29th, 2012, 10:28 AM   #6
Jager
Inspector
Jager's Avatar
I think rather then invest big money and time swapping one working suspension for another, maybe you should check out what some of the pros are using. For example, desert, dune and rally guys are mostly running IFS. There are also a number of rock crawlers using TTB front suspension. Some guys are even installing TTB in the rear, some with full front and rear steering, others just want an independent rear end. I've used this example in the past but, have you ever gone down a road strewn with washboard and pot holes and had your rear end try to pass your front end. The main reason for this is your rear end in a solid or live axle, so when the right side encounters a rut or bump the left side reacts to it Because they are one piece, both sides wash out. Where as the front TTB or any other IFS does not translate that energy to the opposite side but rather isolates the bump, absorbing the hit independently. Case in point, the new Mustang. People have been begging Ford to equip the new stangs with independent rear suspension because when the live axle encounter rough or uneven surfaces, the entire rear end is thrown about making the car unstable. The same with an SAS front end. These are simple facts. Do your home work and you will find that a IFS and in particular the TTB can be made to be a better choice then a live (SAS) axle in most situations. Nothing is perfect, but why not go with what works best in most cases. SAS may look cool and tough, but they have their limitations. Bottom line, is installing a SAS worth the time effort and money? That's your decision to make.
Page generated in 0.18963 seconds with 41 queries
