What year is my 460? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2012, 08:51 AM   #1
chuck202003
chuck202003's Avatar
Default What year is my 460?
Can someone tell me what year my 460 is that I just bought. The numbers on the block is D9TE-AB. Also can you tell me what each digit means.
Thank You
chuck202003 is offline   Reply With Quote
Old March 5th, 2012, 09:32 AM   #2
s.hembree
s.hembree's Avatar
D9TE is a 79 truck block. It's a good block, has longer cylinders for stroker applications.
Old March 5th, 2012, 01:03 PM   #3
bigblocked
bigblocked's Avatar
Yea, it started production in 79 but ran for years. The numbers are actually engineering numbers and not casting codes. The deeper cylinder walls were for the heavy equipment trucks that used longer piston skirts. The most important note for that engine is that it's externally balanced. You cannot fit an internal balanced crank in it due to the cylinder extensions. You're going to find that the aftermarket parts are all going to support the internal balanced engines much more than the external.
bigblocked is offline   Reply With Quote
Page generated in 0.25639 seconds with 32 queries
