Dana 44 Front in a One Ton? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2012, 01:42 PM   #1
Nuggets
I fix stuff!
Nuggets's Avatar
Default Dana 44 Front in a One Ton?
I'm thinking of converting my 1994 Ford F350 to four wheel drive. The truck is a dually and gets stuck on it's own shadow. I can get a divorced t-case no problem but I really don't have the cash for a Dana 60. I have uber easy access to several 3/4 ton Dana 44s that I can pick up for next to nothing. The truck is strictly a street truck and will only have stock tires on it. I mainly need the 4wd to help out when I'm pulling a trailer in low traction conditions.
Another thought I've had is to take a passenger side drop 1 ton axle and converting it to driver's side drop. I'd do that in a heartbeat if I could pick up the axle cheap.
Your thoughts please.
Old March 4th, 2012, 01:52 PM   #2
Toyfish
Toyfish's Avatar
i dont see an issue using a 3/4 ton axle being that it wont be seeing big tires or off road abuse
Old March 4th, 2012, 01:55 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
That's sorta what I was thinking. The truck is rated at 10k GVW but 99% of the time it will be in the 8500# range.
Old March 5th, 2012, 08:15 PM   #4
Red97
best thing to do would be to get a ttb dana 50 out of a 3/4 ton diesel the same year as your truck. also a dana 44 will be quite a bit narrower than a dually axle you would have to run the wheels off of the 3/4 ton pick up
Red97 is offline   Reply With Quote
Old March 5th, 2012, 09:21 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
I'm aware that I'd have to run the 3/4 ton wheels. Its just a work truck so the wheel mismatch is not a huge deal. If I could find a cheap Dana 50 I'd take it. The truck will require a drivers side drop front axle but I can convert a passenger side drop to driver's side drop.
Old March 5th, 2012, 09:24 PM   #6
masterbeatty
masterbeatty's Avatar
you generally can find the dana 50 ttb for under 200 bucks. id say that would be the best bet.
Old March 5th, 2012, 09:25 PM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
Any leads?
Old March 5th, 2012, 09:27 PM   #8
masterbeatty
ill keep my eyes open, generally craigslist. im not tryn to say a 44 wouldnt work, im sure it would actually be fine but a 50 is direct and its all factory so if it breaks and parts place should have the parts in stock.
Old March 5th, 2012, 09:28 PM   #9
masterbeatty
http://grandrapids.craigslist.org/pts/2864147838.html
thats the older dana 44 ttb 3/4 ton im not sure but i think there the same width wise and mounting.
Old March 5th, 2012, 09:29 PM   #10
boggin-machine
boggin-machine's Avatar
Dave if you can get your hands on 1 or 2 3/4ton ford axles id like to pick them up. I could always need one around here
Old March 5th, 2012, 09:29 PM   #11
masterbeatty
http://saginaw.craigslist.org/pts/2873057908.html
Old March 5th, 2012, 09:38 PM   #12
Nuggets
I fix stuff!
Nuggets's Avatar
Good lead. Thanks much!
Old March 5th, 2012, 09:44 PM   #13
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
if you get dana 50 get the wheels to metric bolt pattern, not stadard 8 bolt. and some body on we got mud had one for sale not to long ago. for i thank a round $400.00 you can run wheel spacers so your dually rims work.
4x4xdodgeman is offline   Reply With Quote
Old March 5th, 2012, 09:46 PM   #14
masterbeatty
dana 50 also came in the ttb thats i do believe what he wanted the 50 from a pooperduty wouldnt be a direct bolt in.
Old March 5th, 2012, 09:51 PM   #15
Nuggets
I fix stuff!
Nuggets's Avatar
I want a straight axle. I own a welder. I'll make any axle fit in the hole.
Old March 5th, 2012, 09:53 PM   #16
masterbeatty
haha well then a solid 50 generally is a little more expensive to purchase
Old March 5th, 2012, 10:13 PM   #17
Nuggets
I fix stuff!
Nuggets's Avatar
Like I said, I have access to one or two uber cheap Dana 44s.
Old March 7th, 2012, 07:39 PM   #18
boggin-machine
I have interest in a 3/4 ton hp 44 if you can get a spair Dave.
Old March 7th, 2012, 08:32 PM   #19
Nuggets
I fix stuff!
Nuggets's Avatar
A buddy of mine who owns a salvage yard said he would GIVE me a complete TTB Dana 50 with everything required to install it for free! Sure, I don't like twin shit beam axles but I can't argue about the price.
Old March 8th, 2012, 12:33 PM   #20
Tom
Because racecar
Tom's Avatar
I have a set of dually hubs if you want them. You can take the SRW dana 50 hubs from the ttb and put them on a 60, I'm not sure if you can put the 60 drw hub on the 50 though but it might be worth a try.
Tom is online now   Reply With Quote
Page generated in 0.34165 seconds with 83 queries
