What locker is this? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2012, 07:21 PM   #1
wakeboard76
wakeboard76's Avatar
Default What locker is this?
Its hard to see, but it has spider gears in there, at least one of which is stripped, leaving it constantly locked (unless a tooth sheared off and is wedged). If you have any ideas, let me know. I was told by the PO that this had lock rights front and rear. Clearly this isn't a lock right, its a full carrier type.
wakeboard76 is online now   Reply With Quote
Old March 3rd, 2012, 07:38 PM   #2
wakeboard76
May be a limited slip too, not sure at this point.
Old March 3rd, 2012, 07:49 PM   #3
shawn
Resident HVAC/R Jambi
shawn's Avatar
Is that a D35? maybe an Auburn?
Old March 3rd, 2012, 07:53 PM   #4
shawn
shawn's Avatar
It cold be an older detroit, but I'd have to see the other side of it.
Old March 3rd, 2012, 08:01 PM   #5
wakeboard76
Sorry, should have mentioned this is in my TJ lp D30 with 4.10 gears.
Old March 3rd, 2012, 08:02 PM   #6
wakeboard76
auburn is the closest looking thing i've seen, but the way the cross pins sit is totally different looking to me.
Old March 4th, 2012, 07:02 AM   #7
Dylan
Dylan's Avatar
its a limited slip, not a locker. Power Lock is my guess.
http://www.tomsbroncoparts.com/produ...bronco-rebuilt
Old March 4th, 2012, 10:03 AM   #8
wakeboard76
Yeah, I had come to the conclusion that it wasn't a locker, that's the first picture I've seen that looks right, thanks for the help
Old March 4th, 2012, 02:18 PM   #9
wakeboard76
Anyone who knows where I can find spiders for this, let me know, I'm having trouble finding parts.
Old March 5th, 2012, 01:29 AM   #10
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
are there markings on it? if so, post up. i have something VERY similar in my D44. deffinantly a LSD. maybe we can compare and get a definant answer on what they are.
VAhasnoWAVES is offline   Reply With Quote
Old March 5th, 2012, 02:56 AM   #11
insaneoffroader
insaneoffroader's Avatar
Its a Powerlock. I've got all my rebuild parts through DTS.
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old March 5th, 2012, 05:21 PM   #12
wakeboard76
Nobody shows spider gears for the Dana 30 power lok, would they be the same as a Dana 44?
Old March 13th, 2012, 01:09 PM   #13
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
are you sure its dana30. thay make dana 27 back in the day. run axle numbers or the numbers on the powerlock to see what you have.
4x4xdodgeman is offline   Reply With Quote
Old March 17th, 2012, 09:25 PM   #14
wakeboard76
came out of my tj dana 30 - yeah, i'm pretty sure its dana 30, lol. after a lot of searching, i've learned a few things.
dana no longer produces the power lok
yukon builds them for the dana 44 and a few others
nobody is currently producing replacement gears for the dana 30 power lok
clutch kits are available, but it seems the gear sets on these are the weak link, from the research I've done.
Old April 2nd, 2012, 07:15 PM   #15
oddfirecj5
'71 jeep cj5
oddfirecj5's Avatar
that is in fact a powr-lok limited slip. spicer quit making them in 96 and sold the tooling to yukon nitro. the newer ones suck and are not the best quality. the cross shafts are the weak link. they tend to crack. the dana 27 powr-lok and the 30 powr-lok use the same clutches. you can put in extra clutches to make it more of a posi.
search e-bay and such they are out there but be patient. call R&P 4wd in Oregon talk to paul 1-503-557-8911 they might have parts for you. or call this number and ask for mike 1-612-309-3999 last i talked to him he had a dana 30 powr-lok with broken bolt maybe he would sell it to you for parts.
oddfirecj5 is offline   Reply With Quote
Page generated in 0.28693 seconds with 68 queries
