35" tires x 15" rim on a '98 Ram - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 2nd, 2012, 07:12 PM   #1
SageJp
SageJp's Avatar
Default 35" tires x 15" rim on a '98 Ram
Will a 15" steel wagon wheel rim clear my calipers and bolt on. Also, can I clear 35s with some minor fender/bumper trimming and a 3" lift. Thanks
SageJp is offline   Reply With Quote
Old March 2nd, 2012, 09:01 PM   #2
junkyardjon
15" will bolt on a 1/2 ton.
clear 35's... that i'm not sure.
junkyardjon is offline   Reply With Quote
Old March 2nd, 2012, 09:13 PM   #3
SageJp
SageJp's Avatar
Thanks, I've seen 33's on stock Rams, so I'm thinking they will with some trimming
Old March 3rd, 2012, 01:56 PM   #4
Rosco
Rosco's Avatar
the only way is with a leveling kit
Rosco is offline   Reply With Quote
Old March 3rd, 2012, 02:49 PM   #5
BigCountryDRC
Sexual Ninja
BigCountryDRC's Avatar
I put a 2.5'' leveling kit on my '97 and ran 35''s. You can buy a leveling kit for less than $100 and it takes about an hour to put in.
BigCountryDRC is offline   Reply With Quote
Old March 4th, 2012, 12:18 PM   #6
rammanriley
rammanriley's Avatar
With a leveling kit and 3in body its close but will fit 35's. As for the 15"s Mine had to have a crazy offset to clear the TRE.
rammanriley is offline   Reply With Quote
Old March 4th, 2012, 12:22 PM   #7
rreed101287
you are good to go with wagon wheels
rreed101287 is offline   Reply With Quote
Old April 13th, 2012, 10:50 PM   #8
Jleach0696
Jleach0696's Avatar
as long as the backspacing isnt real deep or they will rub the tie rod ends
Jleach0696 is offline   Reply With Quote
Old April 15th, 2012, 12:59 AM   #9
buddyayres
DAAM Racing
buddyayres's Avatar
Send a message via AIM to buddyayres Send a message via MSN to buddyayres Send a message via Yahoo to buddyayres
im runing 38.5's with a 3" body lift and 3/4 ton springs ( about to inches of lift ). so about the same as a leveling kit. I'm running 15 inch wagon wheels of an old 80's ram. i rub with the 38's but i have no issues at all with the 35's.
buddyayres is offline   Reply With Quote
Page generated in 0.30110 seconds with 50 queries
