Propane Tuning Problem 350 chevy please help!!!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 2nd, 2012, 07:26 PM   #1
cjh4676
cjh4676's Avatar
Default Propane Tuning Problem 350 chevy please help!!!!!!
I have a 350 chevy four bolt main that runs on a propne (Impco 425 mixer). When i push the throttle down about half way the motor just bogs down and sometimes it will back fire when i get about half throttle. Ive turned the mixer adjuster all the way in and turned it out slowly to see if i could get it to stop didnt do anything. Does anyone know why this is doing this?
cjh4676 is offline   Reply With Quote
Old March 2nd, 2012, 07:32 PM   #2
cerial
1200PSIg Double acting
cerial's Avatar
Have you checked the Regulator?
Old March 2nd, 2012, 07:40 PM   #3
cerial
cerial's Avatar
The proper term is gas valve.^^
Old March 2nd, 2012, 08:04 PM   #4
cjh4676
cjh4676's Avatar
no i havnt its a brand new system just got it on there.
Old March 3rd, 2012, 01:53 AM   #5
cerial
cerial's Avatar
There is a lot of discussion on the correct way to tune them. You are doing the hardest part right now. Once you get the settings down there is not much to them. If you try what is said in other forums and still have issues call the company and they will walk you through it.
It sounds like the engine is getting to much lp gas to the lp gas valve without seeing anything. Think a gas valve as a fuel pressure regulator(i do). If a gasoline carb is getting to much gasoline because of a bad regulator in line no amount of adjustment(with a few exceptions) will keep it from running rich and flooding/backfiring.
You can play around with the mixers all day long if you have a over sized or a lp gas valve that is turned up to high it will bog down. Some are adjustable others are not. The initial setup can be a headache and it will take a bit of fuel/try&adjust to get everything just right.
Page generated in 0.20943 seconds with 38 queries
