Yukon Super U-joints for Dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2012, 11:32 AM   #1
SteelTherapy
SteelTherapy's Avatar
Default Yukon Super U-joints for Dana 44
Does anyone know what type of grease is used for these "Super" U-joints? I lost my tube and the grease gun to go with it and I think it's crazy to spend $76 for their gun and 4oz of grease.
http://www.ringpinion.com/b2c/Produc..._Gear_and_Axle
SteelTherapy is offline   Reply With Quote
Old February 28th, 2012, 12:45 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Copper anti-seize grease.
Old February 29th, 2012, 05:53 AM   #3
Cool parts peddler
Ironman Offroad's Avatar
What he said!!
Old February 29th, 2012, 07:25 AM   #4
SteelTherapy
So this is what you mean? Weird, I only thought to use it to keep bolts from siezing.
Old February 29th, 2012, 12:49 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
That's essentially what the u-joint is since there's no bearing. I can't remember the brand (Permatex?) but I think the part number is CA-5 - it's a squeeze tube.
Old February 29th, 2012, 05:35 PM   #6
Carl Jantz, the originator of the patent did a lot of research with different lubricants. This turned out to be the best. I have an email from him that explains his research but it's on my work computer. I'll look it up tomorrow.
Old March 1st, 2012, 08:12 AM   #7
Some info on the Yukon super joints.
Hello, my name is Carl Jantz and I designed and tested the super joint.
Iíd just like to set the record straight for those who think the Yukon super joint is just a cheap copy of other extreme joints on the market today. I have been working on a better U-joint since I broke my 1st front axle U-joint in 1978. After trying every brand, I eventually used Spicerís, but in the old bronco they were the 260x joints, eventually as tires got bigger and several U-joints later, I stumbled on the fact that some Dana 44s used 297x (now 760x) u-joints and bored out my axles to fit. Then of course the ears tore off or stretched, so I built them up with a stick welder and 7018 welding rod. This worked very well for years, then along came still bigger tires and extreme 4 wheeling. I looked at modifying Dana 60 crosses to fit into the D44 caps around 1985 but decided no one would be willing to pay the price of buying 2 U-joints and then machine work to make them work, plus brass bushings that would eventually deform under the extreme pressure exerted upon them. (I didnít know about beryllium bronze at that time). So I built my 1st Dana 60 5 lug front (1986) end and went happily 4 wheelin with 18/44ís for years. Then I went to the 1st NWRCA rock crawl at Vantage Washington and realized that there was a real need for a stronger joint and that a few people would be willing to pay for them. By this time I had worked a Boeing in R & D and had worked with Ionic coatings to drill through Titanium. I figured if It made the drills last significantly longer and since NASCAR was using Ionic coatings on the ring and pinions with great success to reduce friction that they might work on the u-joint crosses to avoid using a bearing. To learn more about Ionic coatings to go to www.Ionbond.com. (Note Ford Model A cars used no needle bearings in their U joints, just 140wt grease and hardened caps on hardened crosses, but then they were only dealing with 40 hp.)
So I had a drill bushing company make some 4340 hardened bushings for me that press fit over the 297X crosses and fit into the caps to replace the needle bearings, and then set up a design of experiments to test various greases and Ionic coatings.
I first used one grease with several coatings to find the best Ionic coating. Then I used one Ionic coating to test several greases. The last test went something like this. Installed 2 Joints into front end of diesel suburban with 4 kinds of greases, one type of grease in 2 caps. Then I pulled out the rear drive line and with my jeep on the trailer behind the suburban went on a 1200 mile road trip including Stevens pass, Snoqualmie pass and White Pass. (Getting started in front wheel drive was a pain sometimes) I then inspected the joints and found out two things. All of the greases were just fine, AND there was water in the joints. Now this was all highway driving in 70 plus weather except one Ĺ hour rain storm, I figured out that as the cold water sprayed up on the u-joints they cooled down creating an internal suction that pulled the water inside the joints, hence they now have pressurized grease reservoirs.
So on to finally test the greases, I chained the rear end to a tree with the front end on dry pavement, and burned a set of tires to the cords in 45 minutes of smoke. All the greases failed except one, and it looked just like I had just assembled the joint and never tested it at all. The grease is an Aircraft spec anti-seize. All automotive greases, even the synthetics never even came close to this stuff.
So with parameters set it was time to combine all factors and do a real world test. 16 joints were made from billet and tested at Cedar City in the April of 2002 at the U-roc crawl. There were no failures and, all of the rigs using the joints placed in the top ten at the event. So onto production, attaining a patent and working with a distributor, and now they are finally here. We really worked on having a product that gives superior performance at a reasonable price. If you would like to see a little more please visit my website for an install. www.jantz4x4.com
Page generated in 0.22901 seconds with 44 queries
