YJ: opinions wanted please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2012, 10:53 AM   #1
yjynot
time to musk up
yjynot's Avatar
Default opinions wanted please
I currently have a 94 yj sitting on 35s. the springs are in need of replacement or repair. The rig is sagging pretty heavy on the passenger side. Currently the springs are approx. 4-5'' lift springs (5pack spring under) (i purchased the jeep lifted, so i am unsure of the exact lift/brand). It does also has longer shackles. I am looking for opinions on what i should replace the springs with (brand/etc.). It is my daily driver so i am looking for a decent life on the springs, but i really would like to get the best articulation without spending a fortune. I have more than enough clearance since wheel wells have been modded etc. so i could drop the lift a bit if i have to. I am also running a sye kit with a t-case drop. i would also like to get rid of the t-case drop for a bit more belly clearance. i would like to stay in the 5" inch range of total lift. looking forward to get some much needed thoughts, thanks in advance.
yjynot is offline   Reply With Quote
Old February 29th, 2012, 09:05 PM   #2
treky67
millwright/jeepwright
treky67's Avatar
Personally rough country makes a pretty good spring. The 4" lift spring should do the trick. they will start around 4.5-5" and settle to about 3.750-4". They also offer a lifetime warranty, and 60 day money back guarantee. I had their 4" lift kit on my YJ and i had a spring sag like 2.5" they sent me a new spring so fast my head spun. And if your jeep is already equipped with a slip yoke eliminator then you can loose the tcase drop its no longer necessary.
treky67 is offline   Reply With Quote
Tags
lift, opinions, springs, yj
Page generated in 0.24448 seconds with 29 queries
