Project: What was I thinking (tracker build) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2012, 08:27 PM   #1
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Default Project: What was I thinking (tracker build)
*Copy and pasting this from another forum.
After smashing the Jeep up pretty good at Snofari I decided to build something else to beat on, on the trails. I'll save the Jeep for the Dunes. So I ended up picking up a Tracker.
Specs:
1992 Geo Tracker 4x4
-5 Speed trans
-ghetto mud bogger lift
-4 stock tires that are junk
-Samurai front axle (bent) with Tracker 3rd/gears
-Factory tracker rear axle (full of water/mud)
-1.6l 8v FI
-clean body minus some dents
-cleanish frame minus some, well, keep reading
-Manual steering
It was advertised as a 1992 Geo tracker with 12+ inches of lift. Geared toyota axles. 4x4 needs work.
This is what came out of the rear axle. Muddy water.
Yes, I was the guy to buy "that thing".
Turns out it actually had samurai axles, not toyota's, so I was able to get it alot cheaper. Its does run good other than an oil leak on the valve cover, and it also drives. The 4x4 doesn't work so I assume it is something in the front axle, probably full of mud/water just like the rear, but will have to look further into it.
Now for my plans.
-Remove the body lift, maybe keep a 1" body lift to keep the trans and tcase up high.
-Swap in new samurai axles with tracker gears.
-YJ's with all new mounts (no blocks)
-fuel cell
-power steering
-33" mud terrains
-lockers
-cage
-armor
-t-case gears
-To be determind...
My goal with buying this was that it was cheap, ran good, had a clean rust free body, and a clean frame. The old spring mounts are pretty small and should be easy to remove. I will eventually be going with toyota axles and depending on how I like the YJ's I may keep them, or link it.
Old February 26th, 2012, 08:28 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
And under all the mud, is a frame! Well most of one. ugh... (also notice the 4x4 piece of wood as a rear body lift)
Only one body mount left in the back...
Passenger rear frame is bent/kinked. Hard to see in the pic, but this is the side that has the factory tow hook thingy. My guess is it was buried in the mud and the lack of rear corssmembers, caused the frame to bend when getting pulled out.
As more work arises towards the surface, I may need a little motivation to keep this from becoming like one of my other zuks, sold.
Old February 26th, 2012, 08:29 PM   #3
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Started the rear frame repair/rebuild
No turning back now.
1.75" HREW tube frame.
Fits like a glove.
Rear shackle mount in it's rough location.
Old February 26th, 2012, 08:30 PM   #4
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Progress pics from this weekend.
Full droop:
I couldn't find anyone with U-bolts in stock that would fit the tracker rear so I made some U- bolt eliminators.
Leaf mount:
Full droop with a 235/75/15 and no trimming yet.
Old February 26th, 2012, 08:32 PM   #5
Shotgun
I only wheel with boats.
Shotgun's Avatar
looks like a good start.
Old February 26th, 2012, 08:34 PM   #6
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Thanks, I hope to have a nice little wheeler when I'm done.
Old February 26th, 2012, 08:46 PM   #7
Strangler
Strangler's Avatar
Sweet plan. Should be fun!
Old February 26th, 2012, 09:01 PM   #8
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Subscribed. Nice progress! Wow on the ghetto mudder lift. LOL
Craig
Old February 26th, 2012, 09:13 PM   #9
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Thanks guys!
Finished welded the rear and set it down. Borrowed some 31s from my dads samurai to get an idea of what it will look like. Looks like with some trimming it will fits the 33s nicely. I hope...
Left to do on the rear:
-shocks and mounts
-brake lines
-bump stops
-limit straps
-Driveshaft
-rear most body mounts
-rear bumper to get rid of my wheel barrel handles
Old February 26th, 2012, 10:40 PM   #10
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
I liked the original lift kit better.
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old February 26th, 2012, 11:01 PM   #11
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Originally Posted by RDK_YJ88 View Post
Thanks guys!
When we went to your dads garage today Joe laughed and said he would be pissed when he came home to find the tires missing.
And it was nice to meet both of you guys. Btw if you're interested in selling the original springs shoot me a pm
Old February 26th, 2012, 11:04 PM   #12
madscience
Ballsohardthatshitcray
madscience's Avatar
Looks like this will be a really fun rig when it's "finished."
madscience is offline   Reply With Quote
Old February 27th, 2012, 04:54 PM   #13
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Thanks guys!
I have a bet going with my girl friend to see how long it takes him to notice.
The "original" springs are some bastard pack of some kind. they look like they put two stock samurai leaf packs together at each corner. You can have them if you want them.
Old February 27th, 2012, 06:55 PM   #14
OnlyInMyXJ22
No Money = No Fun
I think it might take a while, but then again that big Dodge isn't taking up space anymore.
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old February 27th, 2012, 07:26 PM   #15
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I tried to stuff a bunch of crap around it to "hide" it.
Old February 28th, 2012, 08:49 PM   #16
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
The To Do list, that keeps growing.
Todays Progress:
The lowest its been in a while.
Not sure why they welded the ubolts to the axle, front and rear. Trying to prevent axle wrap maybe?
Old leafs out.
Crappy shackle mount that I have to cut off and remake.
Hopefully more progress tomorrow!
Old February 28th, 2012, 11:23 PM   #17
OnlyInMyXJ22
No Money = No Fun
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old February 29th, 2012, 01:08 AM   #18
Fraser
Fraser's Avatar
another go kart... lol
Old February 29th, 2012, 01:39 PM   #19
0Toncaddy
Big Belly Customs
0Toncaddy's Avatar
Trackers don't have much for roofs as it is, but I have faith that you will get it off there.... GO TOMMY GO!!!!
0Toncaddy is offline   Reply With Quote
Old March 3rd, 2012, 02:34 PM   #20
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I've got enough crap to cut off this thing already. I don't need another.
Page generated in 0.42835 seconds with 83 queries
