1998 5.9 Jeep Grand Cherokee - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 26th, 2012, 02:45 PM   #1
ech0sh4y
Default 1998 5.9 Jeep Grand Cherokee
I have a 1998 Jeep Grand Cherokee Limited 5.9 (Rare edition). This means that it has the 5.9 (360) v8 with 46RE auto transmission and AWD qudra-trac transfer case. This jeep is in great shape! very little rust!!! It has new tires, just did a tune up as well which includes plugs, cap/rotor, air filter, pcv, oil/filter change, transmission filter/fluid change, front diff lube. I also just replaced the water pump with a new unit, not reman. Has a new thermostat as well. Intake gasket and plenum plate replaced with upgraded Hughes unit as this is a weak spot on the 5.9s. Also did a timing chain cover gasket as well as replaced the balancer. So pretty much all the main issues with 5.9s are addressed. The jeep has a new Bosch (OE) fuel pump and Ford 24# fuel injectors (new). Also swapped the valve cover gaskets, heater bypass tube, and other misc items when doing this work. This jeep runs awesome! It does need need some minor work though. I bought thinking I would lift it and turn it into an off road rig, but after looking at the condition I've decided I should sell it to someone who may want to keep it stock and try to restore/collect this rare niner. It currently has 124K miles. Everything works on the jeep with the exception of the driver's side heated seat.
It will need brake rotors as they pulse when slowing. The battery is a bit out dated as well, still works fine. The front bumper cover has a crack in it. The rear wiper motor is sometimes operational. Also the rear hatch is a bit tricky at times. There is a bit of rust on the bottom, inside lip of the rear hatch as well. I currently have the front drive shaft pulled as I believe the viscous coupler is heading south (do a google search to learn more about this common issue). I was planning on swapping a 242 transfer case in so you could have 2wd/4wd options. Plus better milage! I do have the drive shaft and can reinstall if you'd like. I can perform the work needed to get this rig 100% for parts/labor cost or you can buy it as is and drive home and work on it when you have time! Super rare jeep that is a blast to drive!!
Was $5,500 OBO
Now $3,500
Email for phone number and details or with offers! May take trades, never hurts to ask!
Last edited by ech0sh4y; August 29th, 2012 at 05:45 PM. Reason: Updated the information in ad
ech0sh4y is offline   Reply With Quote
Old March 1st, 2012, 03:26 PM   #2
ech0sh4y
Feel free to make an offer or possible trade!!! New listing info also!!
Old April 2nd, 2012, 02:32 PM   #3
ech0sh4y
Well I just got done doing quite a bit of work on the ZJ. I had to replace the timing cover gasket. That was the coolant leak! So pretty much tear into the whole front half of the engine. I also then decided to while I was at it to add a Hughes plenum plate (common problem for 5.9). So it has all new gaskets and seals on the top/front of the engine more or less. I also changed out t-stat, water pump, some misc hoses, has a new harmonic balancer, and idler pulley, valve cover gaskets, and I'm sure there is more I'm missing.
Now the jeep still needs to have the brakes looked at and possible fuel pump is starting to go out. I will keep tinkering with the jeep when I get time. I have lowered the price to compensate for the work required. I'm asking $4,800.
Thanks
Old April 2nd, 2012, 02:37 PM   #4
dhotch76
Hotch
dhotch76's Avatar
Not sure I understand what makes this truck rare??
dhotch76 is offline   Reply With Quote
Old April 2nd, 2012, 02:44 PM   #5
ech0sh4y
The 5.9 was produced for only one year, 1998. It was jeeps top of the line SUV and had claimed the title for worlds fasts SUV in production until the SRT-8 WK came out in 2006. There was only 13,000 produced in 1998 and supposedly only half or even less than half are remaining (registered owners). So this is 1 out of roughly 7,000 registered? I thought it was quite rare maybe not to some.
Old April 2nd, 2012, 09:30 PM   #6
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
n00b
SlayerXJ is offline   Reply With Quote
Old April 3rd, 2012, 02:46 PM   #7
bigredjeep1
Well technically 14,243 produced and I had 3 of them in the past year and now just 1. Best Jeep I ever had...and 1 of the best Jeeps ever made period...explamation mark!!!!
I have a 87' Comanche pickup with 4.0L/aw4 auto/231 HP44/9" locked and 4.10 gears on 35" MTs i would trade you for your ZJ.
bigredjeep1 is offline   Reply With Quote
Old April 19th, 2012, 08:50 PM   #8
ech0sh4y
Send some pics and info man! Sorry for the delay!
Old April 29th, 2012, 03:07 PM   #9
ech0sh4y
Alright today I got it running like it should be. I installed a new Bosch fuel sending unit (complete not just pump) $240, and I installed a set of rebuilt (ASNU?) ford #24 injectors $120. Runs great! I also did an oil change and transmission fluid/filter change. Still needing front rotors (not horrible yet). I also noticed a slight rear main leaking oil. Could be something higher up as well.
Still for sale! Super clean underneath and all around for being a wisconsin rig! Please feel free to make an offer or ask any questions.
Old May 21st, 2012, 08:04 PM   #10
ech0sh4y
Bump for new price $4000
Old May 21st, 2012, 09:10 PM   #11
Dune_Trash17
Dune_Trash17's Avatar
If only you were in mid Michigan!
Dune_Trash17 is offline   Reply With Quote
Old May 21st, 2012, 09:20 PM   #12
ech0sh4y
Can always transport it. ;)
Old May 21st, 2012, 09:55 PM   #13
Dune_Trash17
Deliver to Lansing?
Old May 22nd, 2012, 12:29 AM   #14
ech0sh4y
Originally Posted by Dune_Trash17 View Post
Deliver to Lansing?
We could work something out if you are interested.
Old May 22nd, 2012, 09:18 AM   #15
Dune_Trash17
Pm me!
Old May 22nd, 2012, 09:42 AM   #16
michigan maniac
michigan maniac's Avatar
Trade for a 2001 Chevy blazer 4x4 ?
Old May 22nd, 2012, 01:05 PM   #17
ech0sh4y
No thank you on the blazer.
Old May 22nd, 2012, 01:05 PM   #18
ech0sh4y
Pm me!
PM Sent
Old June 13th, 2012, 01:17 AM   #19
ech0sh4y
Bump
Old August 5th, 2012, 01:14 PM   #20
ech0sh4y
Bump to the top for the updated ad!
Page generated in 2.67741 seconds with 83 queries
