My YJ - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2012, 04:26 PM   #21
Jeep ZJ
Jeep ZJ's Avatar
"I guess my alternator had been through one too many mud puddles, so it got replaced with a 136 amp alternator from a V10 Dodge."
ive been trying to figure out the mod for ever! so was it bolt right on? except the pos cable. and did you have to switch pullys? upgrade the wiring??
sexy YJ and bike btw
Old February 25th, 2012, 09:40 PM   #22
tw1st3d5
tw1st3d5's Avatar
If you get the right alternator all the wiring is the same. The only difference is it's a 7 groove pulley instead of 6. Most people will just run on the back 6 grooves (perfect alignment) but you can swap the pulleys.
136 Amp Alternator OEM part # 56027913
1997-1998 Dodge B.Series Van
1997-1998 Dodge Dakota
1998 Dodge Durango
1997-1998 Dodge Ram Pickup
1997-1998 Jeep Grand Cherokee
And other vehicles but those are just a few common ones.
Old February 25th, 2012, 10:14 PM   #23
OhioYJ
OhioYJ's Avatar
Originally Posted by sleeperd2 View Post
How did you do the steering? I'm doing soa but with the Dana 30 under it and 4"lift springs.
I originally ordered a TeraFlex knuckle for my Dana 30. However it ended up on back order, so I temporarily bent the drag link just barely to clear the leaf springs. It didn't need much. By the time the TeraFlex knuckle had come in, I had already swapped in a Dana44 with flat top knuckles and "real" high steer.
Thanks. This should answer your questions about the alternator. You can run the pulley that comes with it, however I suggest you switch and put your stock YJ one on. The YJ pulley is smaller and thus it will spin faster producing both more power and sooner. To be honest upgrading the wiring has been on the list of things to do, but I never actually did it. It's been on there for years with the factory wiring. Peak output measured with my amp probe, while placing a load on the system was 174 amps, so I'm happy with it.
OhioYJ is offline   Reply With Quote
Old February 25th, 2012, 10:31 PM   #24
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I don't think I'd have a stinger that tall, but I really like it!
Old February 25th, 2012, 10:47 PM   #25
DuffMan
Your Message Here
DuffMan's Avatar
Nicely done YJ.
Old February 27th, 2012, 01:04 PM   #26
Jeep ZJ
Jeep ZJ's Avatar
1998 Dodge Durango
But arent the pullys different sizes?
but if you swap the pullys making it spin faster wouldnt it put more wear on it? holw long has it been on your yj, how many times have you replaced it, and where did you get it??
Old February 27th, 2012, 01:25 PM   #27
tw1st3d5
tw1st3d5's Avatar
The upgraded alt has a 7 groove pulley and is just a hair larger. I measured it when I swapped mine and it was something like .07" larger. The 6 grooves closest to the alt line up perfectly with the normal belt alignment on the 4.0. In my opinion it wasn't worth it to swap the pulleys.
Old February 27th, 2012, 01:27 PM   #28
Jeep ZJ
Jeep ZJ's Avatar
no chance of the belt walking over a groove(stupid ? i know lol)
Old February 27th, 2012, 01:34 PM   #29
tw1st3d5
tw1st3d5's Avatar
I guess there is always the chance but the measurements from the mounting surfaces to the first groove were exactly the same. I was running the 7 groove on my 4.0 for Snofari and some driving around town. That's my extent of use since the motor is coming out for a swap.
Old February 27th, 2012, 02:26 PM   #30
OhioYJ
OhioYJ's Avatar
The stock pulley was 20% smaller. I guess theory you might be acclerating wear on it, but I highly doubt you'd ever notice a difference in wear. Mine has been on there for at least 5 years now, never had a problem or had to replace it. I bought it at the local parts store,with a lifetime warranty.
I would definitely change the pulleys, might as well gain everything you can for the 5 seconds it'll take you to swap pulleys.
Old February 27th, 2012, 02:37 PM   #31
Jeep ZJ
Jeep ZJ's Avatar
true. thanks for the info. again nice YJ
Old February 27th, 2012, 05:33 PM   #32
Gunsworth
Gunsworth's Avatar
Originally Posted by roger View Post
nice jeep but that stinger way to big,
Ya I think it needs a beacon on it so no airplanes hit it
Old February 27th, 2012, 05:38 PM   #33
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
stinger was so big it took 7 pieces of pipe to make it!
sbcrichie is offline   Reply With Quote
Old February 27th, 2012, 06:07 PM   #34
OhioYJ
OhioYJ's Avatar
Tube! Well at least, HREW. I decided a round bent tube just didn't look right with the square headlights.
Old February 27th, 2012, 06:19 PM   #35
knixon804
THE GENERAL
knixon804's Avatar
looks sweet.
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JKU UD60s, 40" TRAIL GRAPPLERS, MACHETE BEADLOCKS, AEV BLOWER
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Page generated in 0.47409 seconds with 68 queries
