**SOLD**4 Cylinder Diesel Engine - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2012, 03:21 PM   #1
mr crawl
Mr Crawl
mr crawl's Avatar
Default **SOLD**4 Cylinder Diesel Engine
4 Cylinder Diesel Engine, engine is out of a thermal king refridgeration unit, it still has compressor attached, rolls over fine, has been sitting a little while, I don't kow alot about it, would make a great power plant, generator, or motor swap, these have a sae bell housing, and can be adapted to most automotive transimissions. $350 come and get it out of my way
mr crawl is offline
Old February 25th, 2012, 03:32 AM   #2
drew454u
drew454u's Avatar
got any more info on it?? brand or manufacturer??
drew454u is offline
Old February 25th, 2012, 11:21 PM   #3
mr crawl
Mr Crawl
mr crawl's Avatar
the Engine has thermo king stamped on the block and valve cover, I think isuzu made these for thermo king, either way it would make a good motor for someone
mr crawl is offline
Old February 27th, 2012, 02:11 PM   #4
Paperman
Paperman's Avatar
Any idea if they can be throttled? Dont know in a refer if they are just an on/off.
Paperman is offline
Old February 27th, 2012, 09:57 PM   #5
mr crawl
Mr Crawl
mr crawl's Avatar
on refer units they had adjustment screws both ways for idle and high RPM govener, I have owned other ones and easily adjusted them to more desirable rpm ranges, very simple adjustment I can show someone when they come to buy it
mr crawl is offline
Old February 27th, 2012, 10:30 PM   #6
Sfa_Colorado
RIDGEOFFROAD.COM
Sfa_Colorado's Avatar
Bump that look for a good running motor!!!!
Sfa_Colorado is offline
Old February 28th, 2012, 09:25 AM   #7
ThinICE
Awesome-O
ThinICE's Avatar
You're right that this is an Isuzu engine, it's a C201. The basic specs. for it are listed below:
Cylinders / Bore and Stroke = 4 83 x92
Piston Displacement = 1991cc
Firing Order = 1 3- 4 2
Compression Ratio = 20
Rating power (ps/ r.p.m) = 16/2200
This engine can be throttled, but as noted in the thread, it is set up with a governor on it that maintains an RPM for the specific load to keep the refrig. unit operating correctly. You would have to work with the governor if you wanted throttle control, but there are mechanical and electrical systems out there for that.
ThinICE is offline
Old February 28th, 2012, 10:58 AM   #8
7.3X
Fullsize support vehicle
7.3X's Avatar
Are you looking for trades at all? The wife has my budget pretty thin right now. (too many guns too soon) Pm me if you are looking for anything.
7.3X is offline
Old February 29th, 2012, 02:03 PM   #9
mr crawl
Mr Crawl
mr crawl's Avatar
thanks for the info, I am really looking for cash, first $300 takes it, thanks
mr crawl is offline
Old March 4th, 2012, 12:23 PM   #10
BIGBLOCKXJ
COMMERCE TWP MICHIGAN
How big it is, L W H, is it air cooled?
BIGBLOCKXJ is offline
Old March 4th, 2012, 02:34 PM   #11
mr crawl
Mr Crawl
mr crawl's Avatar
25" tall, 26" long, 18" wide and is liquid cooled
mr crawl is offline
Old March 4th, 2012, 02:54 PM   #12
Gr8wht2000GMC
Gr8wht2000GMC's Avatar
this would be purfect in my International cub 154.....Im thinking
Gr8wht2000GMC is offline
Old March 4th, 2012, 02:58 PM   #13
BIGBLOCKXJ
Any idea how much it weighs?
Old March 4th, 2012, 06:02 PM   #14
mr crawl
Mr Crawl
mr crawl's Avatar
I am guessing between 300 and 400 pounds
mr crawl is offline
Old March 14th, 2012, 12:36 PM   #15
mr crawl
Mr Crawl
mr crawl's Avatar
bump
mr crawl is offline
Old March 14th, 2012, 10:32 PM   #16
haybob
I have some 35" tires to trade
haybob is offline
Page generated in 0.30043 seconds with 71 queries
