1979 chevy 4 x 4 pickup parts****SOLD**** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2006, 04:35 PM   #1
dmcjeep
dmcjeep's Avatar
Default 1979 chevy 4 x 4 pickup parts****SOLD****
No motor and the body is shot.
Axles with frame and body $200.
Tilt steering column $100.
Trany and t-case $150.
Rear sliding window $25
Buy it all for $300.
Has a good grill and headlight assemblys $50.
Heavy duty rear bumper that was used to attach a back blade for snow plowing $75
front drive shaft $50
rear shaft $35
I am not selling the tires but will sell the wheels complete set of OEM rallye wheels with trim rings and centers $125
dmcjeep is offline
Old October 5th, 2006, 04:42 PM   #2
BMFmike
meh.
BMFmike's Avatar
Originally Posted by dmcjeep
No motor and the body is shot. Axles with frame and body $200. Tilt steering column $100. Trany and t-case $150. Rear sliding window $25. Buy it all for $300.
What axles does it have denny?
BMFmike is offline
Old October 5th, 2006, 05:18 PM   #3
dmcjeep
dmcjeep's Avatar
You know I am not a chevy guy so I really do not know. I believe that it is a dana 44 front but the rear I have no idea. The front is passenger drop.
dmcjeep is offline
Old October 5th, 2006, 05:33 PM   #4
trail junkie
Guest
Posts: n/a
Count the bolts on the rear cover, its either a 10 or 12 bolt. #of bolts = #bolt axle
Old October 5th, 2006, 05:44 PM   #5
shawn
Resident HVAC/R Jambi
shawn's Avatar
Half ton, 3/4 ton or 1 ton?
shawn is offline
Old October 5th, 2006, 07:03 PM   #6
dmcjeep
dmcjeep's Avatar
1/2 ton
dmcjeep is offline
Old October 5th, 2006, 08:07 PM   #7
amc78cj7
amc78cj7's Avatar
Bummer that it's a 1979. If it had been a 1972-1977 I could have used the front axle.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline
Old October 5th, 2006, 09:05 PM   #8
dmcjeep
dmcjeep's Avatar
Whats the difference between 77 and 79?
dmcjeep is offline
Old October 5th, 2006, 09:11 PM   #9
amc78cj7
amc78cj7's Avatar
I don't know the specifics, but I can only swap the spindles and calipers from a '72-'77 Chevy 1/2 ton onto our Early Bronco D44. It's one of those well documented internet recipes. Is '79 not 5x5.5 lug maybe?
amc78cj7 is offline
Old October 5th, 2006, 09:25 PM   #10
dmcjeep
dmcjeep's Avatar
That works for me.
dmcjeep is offline
Old October 5th, 2006, 09:28 PM   #11
shawn
shawn's Avatar
He means, he needs the spindles from an early chevy to put on a 44 knuckles so he can run ford hub and rotor 5 X 5 1/2 pattern.
shawn is offline
Old October 5th, 2006, 10:31 PM   #12
dmcjeep
dmcjeep's Avatar
I kind of figured it was something along those lines.
dmcjeep is offline
Old October 14th, 2006, 05:01 PM   #13
dmcjeep
dmcjeep's Avatar
rear end is a 12 bolt and it has 3:07 gears.
dmcjeep is offline
Page generated in 0.24552 seconds with 62 queries
