Project Yota Crawler - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 12th, 2012, 07:09 PM   #101
branch92
Only in a jeep
branch92's Avatar
Rod knock ftw wheel with its not like its gonna hurt it
branch92 is offline   Reply With Quote
Old June 12th, 2012, 07:11 PM   #102
Yotabalt
Locked In
Yotabalt's Avatar
No but it really takes the balls out of the truck...likes to stall out on its own...I doubt it's Gunna hold up well, or even much longer lol.
Yotabalt is offline   Reply With Quote
Old June 12th, 2012, 07:13 PM   #103
Yotabalt
Locked In
Yotabalt's Avatar
That's what it was like right before she got tore down. Lol
Old June 12th, 2012, 07:55 PM   #104
hellspawn
hellspawn's Avatar
Looks good
hellspawn is offline   Reply With Quote
Old June 12th, 2012, 07:55 PM   #105
branch92
Only in a jeep
branch92's Avatar
Oh come on im running this event and I don't run very many
Old June 12th, 2012, 08:01 PM   #106
4Bangler
Jackstand Wheeler
4Bangler's Avatar
wuss.....I smoked the small pit at the mud bog with a rod bouncing around in the pan...if you blow it up you'll be more likely to find another 3.0 and get it going again.
There's a cheap 3.0 in the parts for sale section right now with a "noisy top end"...the seller is a real solid guy....maybe between the two motors you can make one good one and some scrap money for some tube.
Old June 12th, 2012, 08:10 PM   #107
Yotabalt
Locked In
Yotabalt's Avatar
I have most of my tubing already haha...idk I'll think about it, I still have no shocks, or front driveshaft...which is kinda important. Lol
Old June 12th, 2012, 08:36 PM   #108
branch92
Only in a jeep
branch92's Avatar
You still 4 days lol
Old June 12th, 2012, 09:36 PM   #109
Yotabalt
Locked In
Yotabalt's Avatar
I would have to mount a fuel cell, make a spot to mount the pump internally,lengthen fuel lines, make a whole new driveshaft, work a few bugs out and then try goin hard in the mud...I'll be sitting this one out, just not enough time-money ratio to pull it off.
Old June 12th, 2012, 09:46 PM   #110
branch92
Only in a jeep
branch92's Avatar
well i guess next time
Old June 14th, 2012, 08:39 AM   #111
the harvester
the harvester's Avatar
ive got lots of driveshaft parts . if you need help making a new one let me know. now hurry up and get it done for sat lol
the harvester is offline   Reply With Quote
Old June 14th, 2012, 10:11 AM   #112
Timmy
Timmy's Avatar
Negative, it's a parallel 3 link. The panhard bar takes care of the side to side, 3 link is cheaper, and more reliable, not relying on bind to hold my rear straight...at this point I can grab that tire and lift it all the way to the bumpstop, without any bind what so ever, and i am still waiting for someone to justify why the 4 link is so much better, the 3 link does its job well, trail gear, of all companies, would not sell a rear 3 link kit if it wasn't up to par...I feel as they aren't a common build, and people oppose them just for that reason...I'm Gunna run a 3 link in front and rear, I will keep posted to see how it does...
I run a 4 limk front and rear on my jeep. My buddy ran a 3link up front on his. One year at Snofari we were doing some hill climbs and his front end would not hold to the ground like mine would. He was also the one that set both of them up. Just my .02
Timmy is offline   Reply With Quote
Old June 14th, 2012, 01:27 PM   #113
Yotabalt
Locked In
Yotabalt's Avatar
I'm trying but I still don't have all my parts in yet, the front shaft I have a rear from another yota, the ifs Shaft doesn't travel like the rear (meant to be stationary) something like 58* Max vs The rear at 87* max...so I'm running the rear up front, just needs to be shortened, and the cell is tough cause I'm running the pump inside still and made the float work for the cell, kinda cool really, just gotta find a way to make the lines reach...
And the 3 link works for what I'm using it for, she's just a ol' 3.slow with lockers, front is a radius arm-3 link so far from garage flexing it seems pretty good, your buddy might want some better shocks or adjust his coil overs, it shouldn't hop or wander, I don't think ill have a problem.
Old June 14th, 2012, 09:58 PM   #114
branch92
Only in a jeep
branch92's Avatar
you said maybe!!!
Old August 1st, 2012, 11:09 AM   #115
Yotabalt
Locked In
Yotabalt's Avatar
little update, I started bending today, got the jd2 all set up and made a couple templates and all in all, im very impressed with it, makes great bends and it only took me like an hour to have the bend radius and positioning figured out...heres the rear that will protect the tail lights and connect the bars from rear of the frame to the top part of the cab, and the pieces that go over the rear window and main start to the exo, looking like its gunna work out great.
Old August 1st, 2012, 11:29 AM   #116
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Ha! I was going to text you last night (after your G/F accused me of stalking her through the McDonald's drive thru) to see if you had started bending tube yet. Looks good....now for some notching...yuk.
Old August 1st, 2012, 11:32 AM   #117
Yotabalt
Locked In
Yotabalt's Avatar
i have a nice lakewood notcher, with no 1.75 hole saw, and im stuck at work, answering phones haha, i just ordered 4 more sticks of tubing, and if i dont fugle up any bends (havent yet) ill have the rear done tonight hopefully, as long as i can get to a 1.75 hole saw lol.
Old August 1st, 2012, 11:39 AM   #118
Yotabalt
Locked In
Yotabalt's Avatar
i got the stand and everythign mounted, that thing was a pain in the ass with a full stick of hrew , it wanted to hit every wall and leave me no room to make my bends, had to clock it 2 times on the floor, but i think all my bends are short now so i shoulllddd be alright.
Old August 1st, 2012, 11:46 AM   #119
Toyfish
Toyfish's Avatar
Love the build thread did u ever get the video i tried to send u? Im going to finish up pulling my motor either this weekend or next week $200 takes all of it
Old August 1st, 2012, 10:39 PM   #120
Yotabalt
Locked In
Yotabalt's Avatar
Got the rear buttoned up. I like the way it turned out., waiting on steel to do the roof and sliders, also the fenders and hood and front bumper.
Tags
4 link, crawler, lift, rig, toyota
Page generated in 0.36133 seconds with 83 queries
