Project Yota Crawler - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2012, 01:13 PM   #41
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Your not wider.....mine has an ifs rear axle with 1.5" spacers on each side and the front has 3" spacers each side so I am 61" wms to wms front and back...77" outside tire outside tire.
If I had to guess I would say mine is only about 4" over stock.
Old April 11th, 2012, 03:18 PM   #42
Yotabalt
Locked In
Yotabalt's Avatar
I realized after lookin harder at yours, im Gunna run spacers also, and I have 2.75 bs on my rims so I'm stickin out a little ways, i shortened the frame 21" but left axle where it was, I really like your Exo but the P.O. Put a ugly snorkel on mine and it's right in my way, I have a lot to do still, but I'm happy where it sits, yet diasapointed that it's no longer street legal, what did you end up doing with your steering linkages?
Yotabalt is offline   Reply With Quote
Old April 11th, 2012, 03:55 PM   #43
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Mine just has standard highsteer with fj 80 tierod ends. The steering box is pushed as far forward as it can be. The axle is pushed forward do to the rear springs offset plus do to the location of my new hanger. I cut / beat the backside of the fender/ firewall back to the body mount. I have ~ 4" uptravel and the tires rub only lightly.
Old April 11th, 2012, 03:57 PM   #44
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Why is it not street legal?
Old April 11th, 2012, 04:35 PM   #45
Yotabalt
Locked In
Yotabalt's Avatar
Cause here in alpena, anything that has a frame modified, no mudflaps, bumpers that are over 28", and nothing covering the drivetrain is like a having a target stuck on my forehead... They just have nothing better to do.
Old April 11th, 2012, 05:33 PM   #46
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Wow....i could drive it every day and noone would blink lol
Old April 11th, 2012, 06:02 PM   #47
branch92
Only in a jeep
branch92's Avatar
so true... it sucks around here to do anything to a vehicle they really have nothing better to do
branch92 is offline   Reply With Quote
Old April 12th, 2012, 12:01 AM   #48
Yotabalt
Locked In
Yotabalt's Avatar
Got paint crazy tonight, semi gloss white on semi gloss black still needs some finishing.
Old April 16th, 2012, 01:05 PM   #49
Yotabalt
Locked In
Yotabalt's Avatar
4:56 gear ratio and spartan locker
Old April 17th, 2012, 07:02 PM   #50
Yotabalt
Locked In
Yotabalt's Avatar
Progress after some dinner so far.
Old April 17th, 2012, 09:28 PM   #51
Yotabalt
Locked In
Yotabalt's Avatar
Took apart and serviced the locking hubs, also ordered new felts and koyo bearings along with new gaskets from low range off road.
Old April 18th, 2012, 07:53 AM   #52
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I would look into doing the knuckle upgrades (tb eliminator, arp studs, 5th stud) and upgrading the hub studs to 7/16 x 20 tpi bolts while its apart. Even with 35's you run the risk of ripping a knuckle off....i have been there, saw that and it really sucks ass.
Old April 18th, 2012, 12:17 PM   #53
Yotabalt
Locked In
Yotabalt's Avatar
I haven't got to the knuckle yet, If I could afford a tb eliminator id go for it but its deff not in the budget, they show the fully loaded 6 shooters with high steer in every pic but never say wheather it comes with it or not. Cause for 300 I'd have good knuckles and not spend 200 on just high steer arms, also I have been pondering an upper gusset on the front. We will see where money lets me go.
Old April 18th, 2012, 12:22 PM   #54
Yotabalt
Locked In
Yotabalt's Avatar
Also after lookin At all my parts I'm 98% sure the PO had installed tg dirty 30's, I'll have to clean them up the rest of the way and look a little harder, but I have seen the PO had done a few things like the lockouts were in good shape, tg inner axle seal, and the old felts weren't that old or tore up. I'm happy with my 125$ axle.
Old April 18th, 2012, 12:27 PM   #55
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I do not believe the six shooters come with the eliminator. Even if you dont do them invest in some good studs and then do the 5th stud mod...you can make the tabs for the 5th stud yourself (what I did) and its easy to set them up. I would worry less about the upper gusset and more about the ball gussets...those are cheap and to me there is a much greater chance of bending the housing there than there is bending it farther in.
Old April 18th, 2012, 12:32 PM   #56
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
If you want to go really low dollar, torque the knuckle studs the tack weld the steering arm to the knuckle in a few spots then just be sure to regularly check the tightness on the studs. Having the arm come loose really blows and will ruin your day in a hurry.
Old April 24th, 2012, 12:07 PM   #57
Yotabalt
Locked In
Yotabalt's Avatar
Got some front axle parts in yesterday. Still waiting on lots of parts.
Old April 24th, 2012, 05:59 PM   #58
Yotabalt
Locked In
Yotabalt's Avatar
Played with the welder and grinder today...got lots goin on this week. Upper truss will be here tomarrow. Along with the 3rd member freeze plug.
Old April 25th, 2012, 06:39 PM   #59
Yotabalt
Locked In
Yotabalt's Avatar
Fun stuff today-
Old April 25th, 2012, 07:43 PM   #60
hellspawn
hellspawn's Avatar
Looks good
hellspawn is offline   Reply With Quote
Tags
4 link, crawler, lift, rig, toyota
Page generated in 0.31097 seconds with 83 queries
