Project Yota Crawler - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2012, 06:29 AM   #21
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I hope your axle isn't centered at that height, with the trac bar at that kind of angle it's going to move towards the driver's side quite a bit when the front comes up and you get some more weight on the rear....can you lower the frame end trac bar mount enough to get it near level at ride height?
Either way, looks good, you should buy 35's so I can buy your 34's.
Old April 5th, 2012, 04:06 PM   #22
Yotabalt
Locked In
Yotabalt's Avatar
Yotabalt is offline   Reply With Quote
Old April 5th, 2012, 04:12 PM   #23
Yotabalt
Locked In
Yotabalt's Avatar
No it's not centered, I had a couple big dudes jump on it last night. To doesn't bind, and it doesn't move to the drivers as much as I thought it would...the springs need to be turned and the bucket cap needs to be put on...it needs to be aligned the rest of the way. And it needs shocks, straps etc. I couldn't resist rolling it outside today it was too nice out.
Old April 5th, 2012, 04:23 PM   #24
Yotabalt
Locked In
Yotabalt's Avatar
There a little different, but not substantially...like I said I talked with trail gear on measurements, and that's about all I could do, without the huge 75 dollar bracket on the frame side....if it breaks or rides like shit I got some 2x4 square tubing to drop it down with.
Old April 7th, 2012, 06:40 PM   #25
Yotabalt
Locked In
Yotabalt's Avatar
Got bored
Old April 7th, 2012, 07:07 PM   #26
branch92
Only in a jeep
branch92's Avatar
Nice progress
branch92 is offline   Reply With Quote
Old April 7th, 2012, 07:12 PM   #27
Yotabalt
Locked In
Yotabalt's Avatar
There's lots to do still. I have to cap off a couple brackets, mount a tool box and my fuel cell, put the lockers in, and the rear half of the Exo. Somewhere between there the front is getting gutted and start fabbing up the 3 link front.
Old April 7th, 2012, 09:36 PM   #28
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Shouldn't the upper run at an angle to form some sort of triangulation?
I will be linking the rear of mine but its getting four linked for sure. As mentioned on page 1 if you set it up right it will flex everybit as well without the side to side movement.
Old April 7th, 2012, 10:24 PM   #29
Yotabalt
Locked In
Yotabalt's Avatar
Negative, it's a parallel 3 link. The panhard bar takes care of the side to side, 3 link is cheaper, and more reliable, not relying on bind to hold my rear straight...at this point I can grab that tire and lift it all the way to the bumpstop, without any bind what so ever, and i am still waiting for someone to justify why the 4 link is so much better, the 3 link does its job well, trail gear, of all companies, would not sell a rear 3 link kit if it wasn't up to par...I feel as they aren't a common build, and people oppose them just for that reason...I'm Gunna run a 3 link in front and rear, I will keep posted to see how it does...
Old April 8th, 2012, 10:15 AM   #30
benny87
Young Gun..!
benny87's Avatar
What length is your trackbar from CL-CL and what is the angle it is at right now.
benny87 is offline   Reply With Quote
Old April 8th, 2012, 12:21 PM   #31
Yotabalt
Locked In
Yotabalt's Avatar
32" and too much...workin on that today actually.
Old April 8th, 2012, 02:51 PM   #32
Yotabalt
Locked In
Yotabalt's Avatar
Quick update: just moved the track bar down 4", it was bothering me mighty bad so I fixed that problem.
Old April 8th, 2012, 02:57 PM   #33
Yotabalt
Locked In
Yotabalt's Avatar
Trying to see where level was...damn that's higher than this build was supposed to be. Oh well...
Old April 10th, 2012, 02:20 PM   #34
Yotabalt
Locked In
Yotabalt's Avatar
A little unsafe flex for your afternoon...I love that the body stays flat and the suspension takes all the brunt work...
Old April 10th, 2012, 11:43 PM   #35
Yotabalt
Locked In
Yotabalt's Avatar
Progress for the day, ripped the front out.
Old April 11th, 2012, 01:10 AM   #36
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Hope you have a plasma and a shit load of grinding discs!!
That and a case of beer because that part sucks
Old April 11th, 2012, 01:23 AM   #37
Yotabalt
Locked In
Yotabalt's Avatar
I don't have a plasma, and I don't have torches, but I'm Gunna find someone with a set for sure, I did stock up on a f*ck ton of good Cut off wheels...my grinder is feeling the hurt tho...it's gettin a little rattle and grind goin on... Good time to upgrade?
Old April 11th, 2012, 07:54 AM   #38
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Did you measure how tall it was to the top of the cab when it was level? Looks a little high but not bad. I am ~77" on 38's to the top of the exo.
Old April 11th, 2012, 12:41 PM   #39
Yotabalt
Locked In
Yotabalt's Avatar
84" if I remember correctly, cause my garage door is 87" and it nearly wouldn't come out. What kind of lift are you running?
Old April 11th, 2012, 01:05 PM   #40
Yotabalt
Locked In
Yotabalt's Avatar
Man I just ready your build thread, we have 2 completely different beasts... In my pics it's sitting on35's, and you can see my entire frame, also I am goin coils all around and links...and we have diff body styles..so our measurements are Gunna be diff cause newer ones are a little taller. I'm also wider cause I was an ifs and using everything off my ifs to keep it wider. Not hating just comparing, I honestly think mine is too big, I was hoping for 4-6" lift and found myself 11" over where I used to be.lol...
Tags
4 link, crawler, lift, rig, toyota
Page generated in 0.34935 seconds with 83 queries
