dodge transmission I.D. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2012, 09:03 PM   #1
fabguy01
hammer down grabbin gears
fabguy01's Avatar
Default dodge transmission I.D.
so i need to service the trans and adjust the bands. I'm fairly new to dodge so im not sure what trans is in my truck and i need to know if its a 42, 46, or 47 RE ,the adjustments are different for each one. hope someone can help. its a 97 3/4 ton 8800 gvw. thanks Nate. http://www.dodgeram.org/tech/transmi...T_band_adj.htm
fabguy01 is offline   Reply With Quote
Old February 23rd, 2012, 05:28 PM   #2
DodgeDude99
if its an 8cyl it should be a 46re, v10 and diesel are 47re.
but if it was rebuilt and a different front lever was put on then the settings are different.
stock 46 is 2.8 ratio if i remember(its embossed on the arm), when i rebuilt my trans i put in a 4.1 lever, so i sorta average the settings between the 3.8 and the 5.0.
DodgeDude99 is offline   Reply With Quote
Page generated in 0.17388 seconds with 29 queries
