2004 31ft 5th wheel, flat deck SOLD!!!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2012, 11:34 PM   #1
bigbad51ford
bigbad51ford's Avatar
Send a message via MSN to bigbad51ford
Default 2004 31ft 5th wheel, flat deck SOLD!!!!!!
The frame is in great shape still has factory gloss black paint, tires have tread and hold air, was converting it into a dery car hauler. 15,500 tounge weight capacity, two 5,000lbs 6 lug axles with dual brakes It needs a deck, wiring, and tights. 1250.00 and of course open to trades 810-310-0314 txt or call, if i dont answer leave a voice mail with a phone number and I will call u back
Craigslist add
http://detroit.craigslist.org/mcb/rvs/2838584303.html
bigbad51ford is offline
Old February 22nd, 2012, 07:44 PM   #2
snocross2xtremes
snocross2xtremes's Avatar
for being a a 2004 trailer what happend to the deck and all the wireing? or was this like a camper at some point?
snocross2xtremes is offline
Old February 22nd, 2012, 07:49 PM   #3
Jeep ZJ
Jeep ZJ's Avatar
probly a camper
Jeep ZJ is offline
Old February 22nd, 2012, 08:31 PM   #4
bigbad51ford
yea it was a 2004 31ft coachmen, with slide out.
Old March 1st, 2012, 01:06 PM   #5
bigbad51ford
bump
Old March 6th, 2012, 04:25 PM   #6
rideraa
rideraa's Avatar
Trade for 1992 Nite 351, milage approx. 149k, runs good, interior nice, don't use since getting a F350
Clear Title
Last edited by rideraa; March 13th, 2012 at 12:57 PM. Reason: took photos out so your sale thread is not littered
rideraa is offline
Old March 6th, 2012, 11:37 PM   #7
bigbad51ford
could you send me a few more pics of the othr side, and the normal rust areas.. How does the trans shift?
Old March 7th, 2012, 07:15 PM   #8
rideraa
rideraa's Avatar
I will post up more info tomarrow & pics
rideraa is offline
Old March 7th, 2012, 08:22 PM   #9
bigbad51ford
ok sounds good thanks
Old March 8th, 2012, 08:31 AM   #10
rentalrider
rentalrider's Avatar
Interested in trailer. Can i get details of the size of the two decks? Top and bottom. I would like also a pic from the back of the deck if you have one, thanks. Oh, also looking for the distance from bottom deck to top. Looking to make a redneck toy hauler.
rentalrider is offline
Old March 8th, 2012, 04:16 PM   #11
bigbad51ford
I believe the upper deck is 5ft, and the lower deck is 27 ft.... I'll get the rest of your dimension when i get home from work 2mrw.
Old March 8th, 2012, 08:48 PM   #12
rideraa
rideraa's Avatar
More info,
Miles, 168.8k, more then I thought. Batt is out, stored in the house, got driven more then I remembered.
I have owned it near four years. I bought for use when I rebuilt my jeep engine, and keep for back up use till Jeep was paid off. Then got a F350 to tow Jeep.
Never towed Jeep with this, did tow 17' I/O open bow 4 banger which I also towed with the TJ, 5 miles to lake.
Trans, shifts firm on 2-3 shift and reverse, has since I got it.
Cruise works, A/C might, did when I charged it two years ago.
I think it has a bad 02 sensor? Drive a mile and the check lite comes on.
Did not scan it, now code is gone-no batt. Could drive then scan, I have one?
Has small oil drip, holds oil – pan not rusted out, has oil in it now.
Started today on second compression stroke. Has sit 3 months.
Has exhaust leak. Volt gauge inop, was inop when I got it.
PRNDL needle out of alignment was when I got it.
Has a regular box, not flare. PO swapped the flare side box onto a 4WD Nite he had.
He was a Nite fan.
I did DD off and on quite a bit, drove it to Wash DC and back once.
Radio works, CD part inop
Body condition, see below. Sills and floor boards good.
rideraa is offline
Old March 9th, 2012, 08:03 AM   #13
rentalrider
While you are getting measurements, will you measure the ground to beams that have to clear truck box? Want to make sure I'd fit under it.
Sent from my DROIDX using Tapatalk
Old March 11th, 2012, 06:57 PM   #14
rentalrider
Hmmmm... any updates? Still available?
Old March 11th, 2012, 07:05 PM   #15
crazygrady127
crazygrady127's Avatar
You will get a free bump out of this so dont get mad , but am I the only one who noticed that the trailer needs tights ??
Tear It Up - Fix It - And Do It Again
crazygrady127 is offline
Old March 12th, 2012, 12:11 PM   #16
bigbad51ford
I think i'm going to pass on that nite f-150, thanks for the offer anways, and rentalrider, i'll get dims either 2day or 2mrw for you, I had a crappy weekend (snowboarding wreck) lol thankks guys
Old April 30th, 2012, 12:19 PM   #17
rentalrider
Been a month... Anything?
Old May 8th, 2012, 05:33 PM   #18
bigbad51ford
hey, sry, its been a long month for me lol... ill get those measurements 2mrw im sry bout the delay
Old May 9th, 2012, 02:23 PM   #19
bigbad51ford
The Dimensions are as followed....... upper deck is 92in wide x 80in long and is made of 2x5 rectangular tubing, the lower deck is 93in wide x 24ft long made of 10in I-beam, front the ground to the lower deck is apprx 27in, from the ground to the bottom of the upper deck is about 59in, and the distance from the lower deck to the upper deck is about 2ft. I have pictures, and will up load them once i get to work in a few hrs.
Old May 9th, 2012, 07:46 PM   #20
bigbad51ford
pics
ID:	92414   Click image for larger version
ID:	92415   Click image for larger version
ID:	92416   Click image for larger version
Page generated in 0.56712 seconds with 84 queries
