toyota axle help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2012, 02:28 PM   #1
gearhead1985
Default toyota axle help
first let me say i am a jeep guy and mainly mess with ford 9" and dana axles and i don't know shit about a toy axles
ok what happend is my buddy blew up his stock ring pinion and carrier in his 90 4 runner that according to the vin had a v6 from the factory and now has a sbf in it so i go and order a v6 ring and pinion, master install kit and picked up a used carrier off pirate for a v6 now i get all the parts and go to install them the ring and pinion and carrier do not fit and i soon find out i have a 4 cly third so i pick up a used v6 bare slightly modified (holes fro the studs are inlarged two 3/8") third off pirate
now i cant find cairrer bearings to fit what i need is a bearing that will have a 3.255 od and a 1.975 id
i spent 2 hrs looking at every toy carrier bearing at the parts store and i have ordered 3 differnt sets and all are wrong
i am confused
Last edited by gearhead1985; February 22nd, 2012 at 12:35 PM. Reason: fixed bearing size
gearhead1985 is offline   Reply With Quote
Old February 22nd, 2012, 06:56 AM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
The only difference in a 4cyl gear set and a 6 cyl set is the length of the pinion. Many companys dont even make both, they make only 4cyl sets and provide a thick shim to use when installing in a 6cyl carrier.
I dont know what to tell you on the carrier bearing....they are all pretty universal. Generally the only options yiu have when buying a master install kit is v6 or 4cyl, there are no ratio / year breaks thar I can think of, atleast in the pre tacoma mini trucks.
The only thing that pops to mind is maybe the new third you bought is for a tacoma 8.4 axle....they are slightly larger and will not fit in the older 8" housing.
Old February 22nd, 2012, 11:27 AM   #3
BOGDOG
BOGDOG's Avatar
Some of the Cruiser diff's use larger carrier bearings. I have a master install kit for one at home. I will check bearing sizes later.
Old February 22nd, 2012, 12:11 PM   #4
Here's a good reference:
http://home.4x4wire.com/erik/diffs/
He doesn't have the oddball 4.88 / V6 third member does he?
Old February 22nd, 2012, 12:15 PM   #5
Toyfish
Toyfish's Avatar
If it was. Factory 4.88 gear they used a weird housing that u can only get parts for from the dealer
Old February 22nd, 2012, 12:28 PM   #6
Yotabalt
Locked In
Yotabalt's Avatar
Yeah a 4.88 gear is a unique ratio and they used a specific carrier for it...
On a side note, does anyone know of a yota solid front axle up for grabs?
Yotabalt is offline   Reply With Quote
Old February 22nd, 2012, 12:34 PM   #7
gearhead1985
here are pics of ever thing i got
[/QUOTE]
that is the pinion i have not pressed out of the old third since i am having issues with the carrier i was just trying to make it fit
Old February 22nd, 2012, 12:45 PM   #8
gearhead1985
and universal for bearings i can only find 2 differnt ones
i will try to fit it in the housing tonight
Old February 23rd, 2012, 01:08 PM   #9
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
according to the link Jesus provided, even if it is a factory 4.88 third the carrier should be the same...only the ring and pinion, and housing itself was different
Old February 24th, 2012, 12:20 AM   #10
gearhead1985
well the third bolts up to the housing and looking at all the pics it is a standard v6 turbo housing wtf
Old February 24th, 2012, 01:42 PM   #11
gearhead1985
ok i called river city differentals and sean? i think was the guy i talked to is the man he was able to get the correct bearing numbers and orielly's only had one set but they work perfectly
Page generated in 0.35987 seconds with 56 queries
