Basic TJ DD Build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2012, 10:14 AM   #1
wakeboard76
wakeboard76's Avatar
Default Basic TJ DD Build
I decided its time for a build thread, since I have actually been building this jeep since I bought it. I've owned 6 XJ's over the years, two with rusty's 4.5" lifts on them. My first two xj's ended up in MiniBeast's hands, cj7on44's now has my other 2 door, and I just sold my lifted 4 door xj because I found a good deal on a lifted TJ.
Thats the only picture I can find at the moment before any modifications. It has a 2" spring lift, and 2" body lift, on 33" BFG's, 4.0, 5spd, 4.10 gears with lock rights front and rear. D30/35 combo.
First up were new bumpers:
Big thanks to JCR for working a great deal on these, those guys are great and are building some awesome products.
Along with the new bumpers came a new smittybilt xrc8 comp winch, I wanted the synthetic line for weight savings and ease of use. I can tell you after dog party, that it performed very well.
Need more ground clearance, hung up on shovel and fuel tank skid here, once out of the ruts she crawled right up this hill. Made that line the next time around without winching.
I also have a pair of GenRight 4" flare tube fenders waiting to be mounted, since the stock ones have the usual rust on them.
Future plans are as follows:
Install the tube fenders
3-4" long arm lift, loose the body lift.
Upgrade axles: currently planning on a pair of waggy 44's unless you guys can talk me out of this for some reason. The cost of mounts, gears and lockers may end up reaching the point where I'm better off finding a set of rubicon 44's ready to go. I plan on running 4.56 or 4.88's and a 37" tire.
Once axles are upgraded, I plan on purchasing a set of of trailworthyfab's recentered h1's with the 37" mtr. Since this is my DD, the tires will hold up to the street well, the double beadlock will let me air down low enough that the tire should have decent traction offroad (especially if we groove them), and replacement tires are dirt cheap.
Those are the plans at this point, I'm open for criticism, ideas, concerns, etc. Especially open to ideas for axles, I'm not really looking to go to 60's though, just don't want the weight and cost involved. I would be open to an 8.8 rear and 44 front, or 9" rear, something along those lines, just don't want to go full width, I'd like to keep it a little narrower for the trails.
wakeboard76 is online now   Reply With Quote
Old February 21st, 2012, 10:37 AM   #2
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
why long arm? why lose the body lift, are you sure its a two inch lift? and for 37" tires I would run 4.88. However other than a 8.8 in the rear you dont need to do anything to the front to run 35".
Here is how I built my TJ and it went everwhere I wanted it to. D30 with detroit tru-trac in front, 8.8 with ford posi in rear, homemade 2" budget boost, 1" body lift, homemade belly up skid, SYE kit, adjustable uppers in the rear, removed from sway bar, 35" KM2
Old February 21st, 2012, 10:54 AM   #3
mudd_jumper
mudd_jumper's Avatar
It looks good. I had a lot of the same thoughts but due to economics had to back off it all :-(
Would like to see pics of it and how it is all working out of for you?
Old February 21st, 2012, 11:10 AM   #4
wakeboard76
Hancho - I agree with your philosophy, just wanted to take it a step further to run the 37's. I'd also like the flex and ride quality of the long arms. This thing went almost everywhere I wanted at twisted trails, I just want to take it places i shouldn't with this setup. :)
Old February 21st, 2012, 11:13 AM   #5
wakeboard76
I did forget to mention that I also have a 4.7 stroker motor in the works for this, most of the parts and machine work done on that, but that will probably end up being its own build thread, since stroker builds tend to generate a lot of interest, questions, and misinformation.
Old February 21st, 2012, 12:08 PM   #6
Christmas Cookie
what do you want pics of? and i'll dig them up...that set up ran great for three years, then I sold the Jeep
Old February 21st, 2012, 04:54 PM   #7
wakeboard76
I'd like to see pics of your belly up skid if you have them, I do like that idea.
Old February 21st, 2012, 08:33 PM   #8
wakeboard76
Just did a price check on basic parts to put waggy 44's under the TJ:
Brackets from Ballistic Fab Front: 145
Rear: 86
Gears and Lockers from Randy's Ring and pinion:
4.88's: 165 each
Spartan Locker: 290 each
Master Install Kit: 150 each
Thats a grand total of about $1441 not including shipping costs. Ouch.
Old February 21st, 2012, 08:49 PM   #9
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
I get a kick out of seeing that you guy's buy a project jeep from some one off this site. I would not want to buy a jeep from some one who wheeled it like I wheel the one I own. If I were to get a project jeep I would get one from an old lady who only drove it to church on sunday and used it to get groceries.
dougstephvoor is offline   Reply With Quote
Old February 22nd, 2012, 12:52 AM   #10
wakeboard76
Didn't buy this as a "project jeep", I bought as a daily driver. Found this on Craigslist, I doubt this saw much wheeling, definitely none or very little from the PO. Got a steal considering the upgrades to the axles.
Old February 22nd, 2012, 01:03 AM   #11
mudd_jumper
same here got mine off some guy the just drove it to det every day from PH LOL that is all it ever saw was 94 and 75!
Old February 22nd, 2012, 01:27 AM   #12
wakeboard76
Its amazing what people who don't wheel put into these things.
Old February 22nd, 2012, 11:16 AM   #13
Porscheguy
Porscheguy's Avatar
I don't see the problem buying a jeep with a few goodies. Most guys who wheel hard change out the axles anyways..... Most TJ's on the Forum are already 10 years old, have 100k miles and shit is starting to wear out from DD use!
Porscheguy is offline   Reply With Quote
Old February 24th, 2012, 12:12 AM   #14
wakeboard76
debating trying to find some rubicon axles, anyone know a good place to look? If I could find them for less than two grand it might be worth it.
Old February 24th, 2012, 12:48 PM   #15
caveman
GeoDude
caveman's Avatar
get ahold of my buddy ken (rideraa)
pain in the A tj - Great Lakes 4x4. The largest offroad forum in the Midwest
he should have some input.
Old February 24th, 2012, 01:21 PM   #16
wakeboard76
I actually wheeled with Ken at Twisted Trails last weekend...I like his jeep, might consider that same lift actually.
Old February 24th, 2012, 03:35 PM   #17
Christmas Cookie
I copied the teraflex belly-up skid..exactly...mine was homemade, however unless you have access to a very large press and a laser you are not going to make it
Old February 24th, 2012, 04:18 PM   #18
wakeboard76
i figured it would take some serious equipment to copy one of those...
Old February 25th, 2012, 02:41 AM   #19
rideraa
rideraa's Avatar
Ruicon axles are the easy way out, no work, bolt and go.
They can be found for 1k per axle.
You may not be happy with stock ones they have 4:11's, that will cost more to regear.
Waggy axles, the front is stonger then a rubi.
But need modfied to fit. IIRC width is a tad narrower.
Your axles you take off should be worth something, 4:88 & lockers !
Skid, go to jeep forum look up imped he used flat steel and raised his up flush. Took some trans tunnel massage with a small hammer and a cable t case shifter. It can be done. Either way you will want a SYE.
Or you could use a small spacer and flat steel (1/4") and get the same height as a formed tummy tuck skid, no body hammering. Weld a piece of angle or tube on each end to stiffen. Try to get one in the middle too. Drill and die grinder for slots and holes as needed. Counter sink skid for frame holes or use tube as spacer and put over sized hole in skid and keep bolt heads up in tube.
rideraa is offline   Reply With Quote
Old February 25th, 2012, 07:45 AM   #20
caveman
GeoDude
caveman's Avatar
he never tells me anything, he don't love me anymore
I like the direction you jeep is heading though. Keep it up
Page generated in 0.36621 seconds with 85 queries
