good or bad? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2012, 08:15 PM   #1
f250mrozi
f250mrozi's Avatar
Default good or bad?
looking at a 2.5in mini spring pack from readylift to level out my superduty. Is this a bad idea?
http://www.ultimateautoaccessories.c...t/66-2085.html
f250mrozi is offline   Reply With Quote
Old February 17th, 2012, 08:26 PM   #2
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Go BDS They were around 300 and are here in MI
Old February 17th, 2012, 09:08 PM   #3
f250mrozi
f250mrozi's Avatar
Where can you find bds around 300? Been looking on their site and their 2.5 leveling kit is close to 700
Old February 17th, 2012, 09:22 PM   #4
FORD FLARESIDE
Sorry, I was thinking BDS but its their sister company Zone:
http://zoneoffroad.com/product?ki=145&gr=-1
Old February 17th, 2012, 10:54 PM   #5
Elvis13
How much lift can you get before you need shocks?
Old February 18th, 2012, 12:37 AM   #6
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
Maybe 2" or 3" . I did 3" on my XJ and the shocks bolted back on at full droop. Whether or not you should might be a different question.
Old February 20th, 2012, 04:10 PM   #7
Elvis13
i thought we were talking about super duties?
OP, if you do this to the front are you planning anything for the rear? If this truly is 2.5" i would think the front would be a little too high.
Old February 20th, 2012, 04:45 PM   #8
boggin-machine
boggin-machine's Avatar
I will be doing to work for the OP. his truck has such bad rake to it I hope this will level it out about right. I've seen a few trucks with bad take but his is about the worse. Being a quad can long bed it's pretty big. Long truck for sure but this should bring it out about right.
Old February 20th, 2012, 05:06 PM   #9
joe_jeep
welfare wheeler
joe_jeep's Avatar
zone offers a 1" shackle leveling kit for about $80.00
i have it, but have not installed yet.
Old February 22nd, 2012, 10:52 PM   #10
tom77cj5
tom77cj5's Avatar
I did a similar kit on a buddies truck. Its a glorified lift block made from short leafs. Reused his stock shocks with no issues. Truck sat level and looked totally different
Old February 22nd, 2012, 10:56 PM   #11
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I had tha tone on mine. I still ended up adding another inch in the back because it really brought it up there. I just wanted the back a touch higher since I used to tow a lot. If you don't tow much it will be great.
It was a bit of a job to do though. If I was to do it all over, I would have done the shackle lit.
Old February 23rd, 2012, 05:49 AM   #12
88fordman
88fordman's Avatar
We just put a zone 2.5" kit on my friends F-250. It really brought the front up high, but settled in after a few weeks. This front lift will not require shocks as they bolt to the spring plate on top. We then replaced the 250 blocks with 350 ones to bring the rear up a little...we also installed the 350 rear shocks because they are a little longer. I could probobly get you some pics if you wanted. The truck sits great like that.
88fordman is offline   Reply With Quote
Page generated in 0.32778 seconds with 59 queries
