how to cut tires?? hot knife is to slow! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2012, 07:31 PM   #1
red87chevy
red87chevy's Avatar
Default how to cut tires?? hot knife is to slow!
What dol you guys use to cut tires??
I got 8 hours into a 44 and its still not done anything work really good?
red87chevy is offline   Reply With Quote
Old February 17th, 2012, 07:33 PM   #2
firehawk
Live Action!
firehawk's Avatar
Chainsawz
Old February 17th, 2012, 07:35 PM   #3
jeepjumper
Does not own a jeep...
jeepjumper's Avatar
butter knife
jeepjumper is offline   Reply With Quote
Old February 17th, 2012, 07:36 PM   #4
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
4" grinder. I have tried it all and the hot knife works the best. Make sure its real hot and ya have atleast a 12 pack
Old February 17th, 2012, 07:53 PM   #5
firehawk
Live Action!
firehawk's Avatar
Dualsaw
Old February 17th, 2012, 08:05 PM   #6
red87chevy
red87chevy's Avatar
I've been useing a piece of 3 foot 1 inch pipe sharpened and put in in the wood stove for a minute and it rips chucks but still to slow cuz you gotta reheat
Old February 17th, 2012, 08:19 PM   #7
boggin-machine
boggin-machine's Avatar
the tire cutter is the only way to do it correctly. suck it up sally
Old February 17th, 2012, 08:21 PM   #8
Bones
Bones's Avatar
ideal tire groover. Should only take about an hour per tire.
preheat the tires if you can. putting them in the sun on a warm day does wonders. otherwise put them in your garage, aim a torpedo heater at them for a 20 minutes while trapping the heat with a tarp.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 17th, 2012, 09:06 PM   #9
The idal knife is what I use. Its cheap, but it works. I do them on the vehicle, with a 500 watt halogen light shining on the section next up to be grooved. I spent about 45 minutes per tire on my 38.5x14.5 SXs.
Now, if you want to spend bucks, the rilfits are nice but several hundred bucks.
If you are removing large chunks, then I'd make a couple custom big sharp metal hunks into knives and have them in a fire, or use a sawzall with a razor knife.
Not sure how you are spending 8 hours on 1 tire, unless you are completlely comp cutting it.
Old February 17th, 2012, 09:08 PM   #10
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
You are a "Smart Man" .......and I feel like an idiot.
I should have used my paint lights sitting in the corner of my barn instead of trying to keep the heat gun blowing on the tire while I was cutting.
Old February 17th, 2012, 09:10 PM   #11
michigan maniac
michigan maniac's Avatar
Ideal tire groover and use a blow torch to preheat the tire, I can do a single 44 inch tire in about 45 mins to an hour
Old February 17th, 2012, 09:12 PM   #12
I got that tip from someone else on here, so I can't claim credit for it. But it worked decent for me.
The biggest thing I found with the knife is it works better to do a shallow groove, then make it deeper with a 2nd, maybe a 3rd pass. Can be faster than trying to take a big deep cut, that takes too much heat out of the knife.
slower - faster it seems. Going easy is also a lot better on the blades. If you ahve to push hard, they don't last. I cut my own blades by slicing thin strips off razor blades and heating thme with a torch into the right U shape. They last longer than the ideal blades.
Old February 17th, 2012, 10:06 PM   #13
red87chevy
red87chevy's Avatar
I'm comp cutting 44 hawgs into v tread style I take almost 25 pounds off each tire so it takes awhile just looking for a good way to do it
Old February 17th, 2012, 10:37 PM   #14
THen yeah, an ideal knife is probably overmatched.
I'd make a blade, like a 3/8" thick piece of steel with a sharp edge ground in, weld on a handle, and keep it ripping hot with a charcoal BBQ or a torch or something, and use that like a hot chisel to take big pieces off.
Old February 17th, 2012, 10:47 PM   #15
AceMon
Could've had a v8
AceMon's Avatar
AceMon is offline   Reply With Quote
Old February 18th, 2012, 12:31 AM   #16
92FleXj
stacks stacked on stacks
92FleXj's Avatar
I know it sounds stupid but look how fast he cuts these boggers with a wood chisel and a torch.
Old February 18th, 2012, 10:47 AM   #17
michigan maniac
This is how I cut mine... And under an hour each to.do it, I have the groover and blades to.do it if you need help
Old February 18th, 2012, 12:24 PM   #18
cutting boggers - YouTube
Yeah, thats kinda what I was suggesting. Haven't seen it done with a chisel, but if you don't mind killing one just for that purpose, it should work fine. You want as much thermal mass as possible.
Old February 22nd, 2012, 10:42 AM   #19
red87chevy
red87chevy's Avatar
Best thing i found so far is a piece of pipe hot ande sharp
Old February 22nd, 2012, 05:32 PM   #20
michigan maniac
What size blade on the hot knife are you using? There's no way you should have 8 hours into.one tire
Page generated in 0.29899 seconds with 84 queries
