running hot blowing cold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2012, 09:41 PM   #1
mudzuk21
mudzuk21's Avatar
Default running hot blowing cold
so my temp gauge is saying its hot close to over heating but its blowing cold air but the engine radiator and hoses feel to be at normal heat theres no smoke cant smell anti-freeze burning changed the thermostat think thats what it was and nothing any ideas. thanks
mudzuk21 is offline   Reply With Quote
Old February 16th, 2012, 09:46 PM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
bad t-stat????- well make that bad replacement t-stat? I've gone through 2 or 3 before I've gotten a good one lately. Stant's QC blows lately.
Old February 17th, 2012, 05:56 AM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
feel the coolant lines going to the heater core. Both should be hot. If only one is hot you probably have a clogged heater core. I've also seen a bad head gasket act this way as well.
Old February 17th, 2012, 05:59 AM   #4
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
x2
ATOMIC_BADBOY is offline   Reply With Quote
Old February 17th, 2012, 10:47 AM   #5
Elvis13
aftermarket temp guage? Most stock gauges i have encountered don't do shit.
Any chance you can get a laser thermometer. A few checks and you may be able to find a cold spot somewhere and locate a possible blockage.
I would also flush the system, AF does not lose its cooling ability but it will lose its corrosion resistance over time.
Old February 17th, 2012, 06:32 PM   #6
scottie
Eye candy
scottie's Avatar
Air in the system will also do this.
Check your water temp sensor, you can use a ohm meter to see what it's at to figure out if it is the sensor, gauge, etc.
Page generated in 0.21371 seconds with 41 queries
