98 S10 blazer 4x4 4dr with pics $$2100$$ obo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2012, 06:37 PM   #1
redneck
rebel
Default 98 S10 blazer 4x4 4dr with pics $$2100$$ obo
I have a 98 blazer up for sale.Has power windows,Power Locks,Remote start/keyless entry. Truck has 163,xxx miles on the body and trans, shortly after buying it the motor went out. so it has a motor from another 98 blazer that had 115,xxx on it motor was from dertas junk yard That is about the only receipt I dont have for this truck(but i beleve you can see dertas markings on the motor) I have relapsed the following items which i have most recepts that will come with the truck.....Ill start from the back and go to the front on the items i have replaced
differential cover (also had it powder coated)
axle seals
u-joints front and rear both drive shafts
torque converter (was told that the sound i heard was that going out but was really a spun bearing in motor)
flywheel (for the same reason above)
driver side cv axle
ball joints
ceramic break pads on front and back
new rotors in the rear
new wheel bearing on passenger side front
new ignition coil
new crank sensor
new pick up coil
full tune up
new intake gaskets
cold air intake
new alternator
new oil cooler/cooler lines
xenon high and low beam headlights
i also installed a set of factory blinkers that have the fog lights built in
has rear brake light covers
tires are fair front tires are the worst of them and that was due to bad ball joints (only low tread on outside edges)
truck also has a custom exhaust on it cat converter delete for better mileage 3" exhaust from where the cat was to muffler than 2.5 from muffler to tip muffler is a thrush welded tip is a 3" tip coming out the rear (but because the cat is not on the check engine light is on no big deal tho)
most all items replaced on this truck were bought new all oil changes were at or before 3000 miles
also had a tranny flush at the time of torq converter install
front seats are in good shape just like the look of those seat covers
the bad
check engine light is on but its from the exhaust see above
abs doesnt work never has not sure why but truck stops fine just no anti lock
needs a motor mount installed but comes with it brand new in the box
also needs a 4x4 actuator cost 50 bucks new or like $10 used (transfer case locks in but the actuator has a rip in it so the vacume wont lock the front in easy fix)
also the lower air dam is broke but was that way when i bought it
truck has a couple dents (small dents) on passenger side fender as well as a scratch going down the fender but doesnt look bad at all and looks nice when all washed lots of shine in the paint
Im putting this up for sale for 2100 or best offer no lowballers obo with in reason
text me @ 231-720-nine450 or email jream77@lycos.com thanks here is also a youtube video of truck as well follow the link below
ID:	89175   Click image for larger version
ID:	89176   Click image for larger version
ID:	89177   Click image for larger version
redneck is offline   Reply With Quote
Old February 13th, 2012, 10:59 PM   #2
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
interested in a partial trade and cash???
spr_chicken is offline   Reply With Quote
Old February 14th, 2012, 08:19 AM   #3
redneck
rebel
what do you got?
Old February 14th, 2012, 09:34 PM   #4
rjh6355
rjh6355's Avatar
Trade for a 96 grand cherokee? Runs and drives great.
rjh6355 is offline   Reply With Quote
Old February 14th, 2012, 09:41 PM   #5
redneck
rebel
no thanks dont really need another vehical just got a xj
Old February 15th, 2012, 05:22 PM   #6
redneck
rebel
up
Old February 16th, 2012, 09:22 AM   #7
redneck
rebel
bump
Page generated in 0.23103 seconds with 46 queries
