toyota timing... and Cam question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2006, 07:02 PM   #1
Pre4runner
Bike Dude
Pre4runner's Avatar
Default toyota timing... and Cam question
Ok so the 22re is running and timing hasn't been set quite yet... well kinda but not right... one i need to get a tach and 2 what do i have to short out.... where is it on the truck actually?
Who is running a different cam shaft and any trouble?
Did you change springs... rockers?
Anyone ever play with the mass aitflow sensor? like downey talks about rotating the gear to lean or richen it out? I have a spare to play with.
Old October 5th, 2006, 06:02 AM   #2
roll-bar Bob
roll-bar Bob's Avatar
YES ALL OF THE ABOVE!!!
I GOT TO RUN BUT I WILL BE BACK
Old October 14th, 2006, 01:14 AM   #3
Pre4runner
Bike Dude
Pre4runner's Avatar
Same thing mine runs and is torque down low but doesn't rev up high... seems to be starving... dont know need to install a tack but its acting like a i put a torque cam in it and all i did was a mild mid to upper.
Old October 20th, 2006, 04:48 PM   #4
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
number 1 Downey is crap! go to Pirate read the FAQ and everything you need is in there.
Don't screw with the AFM, the computer will reset itself after time to the new settings.
I ran an RV cam in my runner on stock rockers/ springs no problem. the valve lash needs to be set at 7/11 or if your really good 6/10(HOT).
I ran mine at 6/10(HOT) and it had good power from mid through 6000 rpm.
Timing should be set at 5 degrees with the jumper in. when you put the jumper in the idle should drop, if not you need to set your TPS.
the timing can also be set at 10-12 with no jumper, if memory serves right.
look here for an online FSM : Toyota Manual
nmeinc is offline   Reply With Quote
Old November 21st, 2006, 09:32 PM   #5
Pre4runner
Bike Dude
Pre4runner's Avatar
Ok so this jumper.... where is it, i think this is my big problem right now... other then something else.
The vent can for the gas tank fills with gas and the vacuum for the tank sucks gas in???????
O and my problem was the timing chain was off one tooth.
Old November 21st, 2006, 09:49 PM   #6
Do you know Roger Browns site? I thin its 4crawler.com or something similar. He has photos of the conenctors and pages of helpful stuff. Very good reference. The location of those connectors varies based on earlier or later vehicles, on my 85, its along the drivers side fender, behind the airbox.
Yeah, that sounds like the cam was off by one tooth.
I keep meaning to toss a cam in mine, since I'm too lazy to swap the motor. Comp's 252s seems to be the most popular choice, as well as engnbldrs crawler C cam.
Old November 22nd, 2006, 06:39 AM   #7
Rattler
Home Sweet Homicide
Rattler's Avatar
Seeing your in Bay City too, I got Chiltons and a Haynes manuals for the Toyotas if you want to borrow them. Not sure how much help they will be.
Old November 23rd, 2006, 10:56 AM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
teh comp 252 is their low end right? I actually have the stock cam in for the moment so i can get the thing running and broken in correctly. soon as thats up im sure im putting my cam back in... maybe an lc adjustable timing gear so i can degree the cam in just right
Old November 26th, 2006, 12:38 AM   #9
Pre4runner
Bike Dude
Pre4runner's Avatar
Autozone's online thing had the pics i was looking for and some useful info.
http://www1.autozone.com/servlet/UiB...3d801ba400.jsp
Old November 28th, 2006, 04:02 PM   #10
hunter2005
kyle whats going on how was the mounds...and i'm keeping the yota.....so its on
hunter2005 is offline   Reply With Quote
Old November 28th, 2006, 04:32 PM   #11
Rattler
Home Sweet Homicide
Rattler's Avatar
HA! You're making the right move Hunter!!
I popped my Mounds cherry Sat. Nothing too crazy (meaning no water/mud in the cab).
Page generated in 0.26645 seconds with 56 queries
