Ford ranger SAS guys out there? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2012, 10:06 PM   #1
demon-fx4
03 FX4 LEVEL II on 32 KM2
demon-fx4's Avatar
Default Ford ranger SAS guys out there?
i'm going to SAS my ranger and i been looking at a dana 44 hp axle from a early bronco. good axle to use? have any advice for me? like what sould i deff do well building it and what shouldnt i do. i was thinking 3 link front and 4 link rear ford 9 inch rear end. any pics of ur guys rigs?
demon-fx4 is offline   Reply With Quote
Old February 12th, 2012, 10:55 PM   #2
Elvis13
If you are actually going to go through with this it would be nice to know what you plan on doing with it.
When do you plan on starting the build?
Old February 12th, 2012, 11:20 PM   #3
demon-fx4
demon-fx4's Avatar
i am planing on this. dana 44 front with 5.16 gears with a ford 9 inch rear. up to 7 inches of lift with 36 to 37 inch tires. 4 link rear and 3 link front. coilovers all around. it will still be a DD. exocage with snorkle. i am looking for a 4BT cummins for after the sas. also i would like it to be a twin stick as well.
Old February 12th, 2012, 11:21 PM   #4
demon-fx4
demon-fx4's Avatar
i plan on starting the build as soon as i get most the main parts so i make sure i dont mess it up or forget stuff.
Old February 13th, 2012, 05:07 AM   #5
MARTIN HASSENGER
BRONCATRON
MARTIN HASSENGER's Avatar
Don't think they made an EB hp44 I believe there all LP but u can cut down a 78-79 full sized to be the same width. Also I think 5.16s for daily use with only 37s will be to much, 4.56 would be more practical IMO. Do they even make 5.16s for the 9s/44 I thought 5.13 was the lowest u could go but I'm not sure on that.
MARTIN HASSENGER is offline   Reply With Quote
Old February 13th, 2012, 06:48 AM   #6
Petti
Petti's Avatar
I would recomend going full width Dana 60.... At a minimum 64" and
5.13's is the way to go....
Things get tight in the front of that truck.
Petti is offline   Reply With Quote
Old February 13th, 2012, 07:30 AM   #7
demon-fx4
demon-fx4's Avatar
see idk i'm still learning all this stuff that y i figured i would ask the guys on this forum cuz everyone here seems to know there stuff.
Old February 13th, 2012, 09:16 AM   #8
Petti
Petti's Avatar
Having a TJ with a waggy 44 and building a SAS 98 ranger with a 44, we both ended up adding 2" spacers and had to upgrade to cromos with 37's
He was running 5.13's with a 3.0L auto, and with a 5.0L auto.
Old February 13th, 2012, 09:27 AM   #9
Freak
Wheelin the HD
Freak's Avatar
You should buy my 44/9
Old February 13th, 2012, 09:36 AM   #10
2fst4you
2fst4you's Avatar
If you are going to run 37s and coil overs which are very expensive I'd suggest doing a d60 front that way its done and you don't have to worry about breaking the 44 now or when you go bigger in the future. If you can stick to 35 or 36s now a 44 will work but your going to want chromos soon or atleast by the time you go to 37s. That's about your limit on that axle. Being as its your DD I'd run 4.56s or 4.88s at the lowest. You can go to 5.13 or 5.38s when she's just s trail rig
Old February 13th, 2012, 02:33 PM   #11
demon-fx4
demon-fx4's Avatar
i can run a 35. i have 32's right now with 4.10's
Old February 13th, 2012, 02:37 PM   #12
demon-fx4
demon-fx4's Avatar
lol and how much? lol
Old February 13th, 2012, 02:53 PM   #13
Freak
Wheelin the HD
Freak's Avatar
72 lp eb 44 4.88 gears and trutrac, disk breaks high steer arm on the right knuckel for crossover steering. The tie rod ends are good but the connector is bent complete axle down to the lugnuts.
Rear 72 "big bearing" 9" 4.88 gears with a spool and disk breaks complete to the lugnuts.
Looking for $1600 for both, they are assimbled and ready to run.
Old February 13th, 2012, 02:58 PM   #14
demon-fx4
demon-fx4's Avatar
sounds like a good deal. what did u have them on?
Old February 13th, 2012, 03:02 PM   #15
Freak
Wheelin the HD
Freak's Avatar
00 s10 on 35's
Old February 13th, 2012, 03:07 PM   #16
demon-fx4
demon-fx4's Avatar
ya i remember u u came to my place in lowell to pick up a spare tire i think
Old February 13th, 2012, 04:23 PM   #17
Freak
Wheelin the HD
Freak's Avatar
Yep.
Old February 13th, 2012, 04:28 PM   #18
2fst4you
2fst4you's Avatar
If you run 35s I'd buy freaks axles hell of a deal
Page generated in 0.31185 seconds with 77 queries
