7.3 idi oil pressure problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2012, 12:00 AM   #1
heavy74chevy
heavy74chevy's Avatar
Default 7.3 idi oil pressure problems
So i have a 93 idi. The stock oil pressure gauge was movin all over, after its warm if i push in the clutch and let off the pedal i loose all oil pressure. I put in a sun pro electric gauge and it does the same thing. I hooked it up where the stock switch was on top of my turbo. At stop lights i hit zero, but it still sounds fine,im baffled. Any input would be greatly appreciated.
heavy74chevy is offline   Reply With Quote
Old February 12th, 2012, 03:59 AM   #2
IDIeselman
IDIeselman's Avatar
The factory sending unit is nothing more than an on/off switch. If you wish to know the correct pressure install a wet gauge.
Old February 12th, 2012, 08:26 PM   #3
heavy74chevy
Do you meen a mechanical gauge? I put in electric sunpro and its still doin it. I guess my question is, is the turbo a good place to hook the aftermarket gauge in or should i have it pluged in somewhere else
Old February 18th, 2012, 07:53 AM   #4
chevyk10
FORD / GM
chevyk10's Avatar
Key word "electric". Go with a machanical gauge.
chevyk10 is offline   Reply With Quote
Old February 18th, 2012, 08:04 AM   #5
curbdog17
Mini Van
curbdog17's Avatar
Mechanical gauge will tell you the truth.
Old February 18th, 2012, 09:18 AM   #6
chevyk10
FORD / GM
chevyk10's Avatar
x2 EVERY 80s and 90s Ford truck I've owned has had problems with the electric pressure gauge (I've owned about 10). You could just replace the electric sending unit but it would just be pointless cause its a dummy gauge anyway. Just get a real mechanical gauge.
Page generated in 0.25430 seconds with 41 queries
